    Lives in East Lothian, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I'm an idiot at times.
    Something I never tried was changing from Sculpt to Model mode, which means everything works how it should, and I can mirror the body and adjust proportions, with no need to convert to T-splines, which Sculpt mode relies on. I wrongly assumed that because Fusion opened the various file types in Sculpt mode, I had to use it.
    As a further discovery, Mesh mode handles the STL fine, however it's got no option to mirror anything.
    This is part of me seeing how capable Fusion 360 really is, but I'm still not sure I'd trust Autodesk with keeping all my files secure in their cloud. BobCad is the other option I'm considering, but it gets a bit pricey to get adaptive toolpaths, but at least it's not subscription based.
    Good to hear you've got it sorted!
    I think this is the guy with the best fusion360 vids in my opinion. https://www.youtube.com/user/cadcams...able_polymer=1 I just like his style
    Now I'm wondering how to model it fusion :)
    Hardest part was the transition section. IIRC it was some variation of a Loft I used, but it took a good bit of tweaking to get something that looked reasonable. It still doesn't look 'right', but it's good enough for something that's purely decorative.
    I played for a bit and never got very far lol but I just realised it's probably quite simple with plane along a path and some loft/extrudes but got to go out now will have another play when I come back.
    Corners are just a basic arc, revolved. Rollers/humps are basically 3 arcs, trimmed, then extruded.
    You then need to use a type of loft between the two, however to get the smooth transition you have adjust how the inner high edge flows, so you start/finish level with a smooth arc, which I honestly can't remember how I managed it. I do seem to remember going through lots of options in solidworks to find something that would work.
  8. The Following User Says Thank You to m_c For This Useful Post:
  1. fusion 360 cnc parts
    By charlieuk in forum Fusion 360
    Last Post: 24-05-2017, 02:23 PM
  2. Fusion Problems
    By cropwell in forum Fusion 360
    Last Post: 04-03-2017, 07:39 PM
  3. Fusion 360 - best approach?
    By routercnc in forum Fusion 360
    Last Post: 18-06-2016, 07:49 AM
  4. First go at Fusion 360 Adaptive Clearing
    By Washout in forum Fusion 360
    Last Post: 15-10-2015, 07:52 PM
  5. Fusion 360 - full, free 3D CAD and CAM.
    By Leadhead in forum Fusion 360
    Last Post: 24-06-2015, 11:31 PM
