Thread: Newbie new build
Hi Guys
My first post.
I have limited budget but like most people would like to get best bang for my buck (actually pounds).
I want to cut glassfibre and carbon fibre sheet up to 5-8 mm.
Various timber up to 25mm (ply, mdf, some hardwoods)
I would also like to cut Aluminium upto 30mm (nothing too fancy just brackets for 22-25mm tubes).
I have relatively good experience at various engineering and workshop skills so am not put off self building.
However I do not know much about CNC builds other than some basics from trawling the web. (which brought me here)
My Budget is around £500-700
I quite like the look of this machine https://www.youtube.com/watch?v=6g0k9oSLejQ
But there is limited info on it.
I am looking at these two items to buy:
http://www.ebay.co.uk/itm/Revolution...QAAOSwP4ZZwxpL
or
http://www.ebay.co.uk/itm/Cnc-Kit-3-...oAAOSwhYdZ2y6u
The spindle:
https://www.ebay.co.uk/itm/EU-STOCK-...8AAOSwuMZZGX~J
or
http://www.ebay.co.uk/itm/EU-Quality...UAAOSwuk1Zu4L3
Would this spindle be good powerful enough to do what I want? and those driver packages and stepper motors how suitable are they or are there better options, I see some are using arduinos but that package including motors seem reasonable?
Any recommendations on design,,,,,(I'd like to build as big as possible)
I was looking at the Ox on youtube and elsewhere but unsure what design would be best and where to start from here?
31-12-2017 #2
Hey Heliox
Welcome to the forum
I’m not very experienced in building a cnc router and currently under the design stage an when I’m done will put it up to be judged lol from what I’ve ne reading an researching, I think your budget might need to stretch abit more if your looking to do aluminium aswell, there’s plenty of people who can refer you to contacts to get parts cheaper an deals, also don’t order your electronics until your design in in place as things will change and you don’t want to be stuck with parts you’ve brought that aren’t no good,
The design your looking at if you go onto the guys channel he has got a build log to give you a better understanding of his design, and I believe them Nema motors your looking at are too small nM wise, I think they would suit a 3D printer more, the standard seems to be 3nM or more from what I’ve read.
With regards to the spindle water cooled is the best option, for the amount of noise a air cooled produces and at low speeds might not cool the spindle efficient enough, again people can give you contacts to sort that for you with a vfd to go with it, best thing is start with your design and there’s plenty of sticky threads to help with your design an then go from there.
Again I’m not a expert but there are a lot on here so just thought I’d give you a few things from what I’ve been looking at and reading, looking forward to seeing what you design
All the best
31-12-2017 #3
Those kits look attractive, but are underpowered (low-torque steppers, low voltage PSU, inadequate drivers) and the TB6560-based version also has the problem that all the electronics is integrated on to one board so when one of the drivers goes pop (these versions do...) you have to scrap the lot.
The electronics is not the right place to start. Although you have talked about the materials you would like to cut, you haven't mentioned cutting area which is a major design driver. And although everyone would like to cut aluminium, that's a big step in rigidity and accuracy over and above what's needed for wood.
Give a bit more detail on your machine needs, and look through the build logs on this site. It's a bit of a trawl through a lot of threads, but there's a good chance that someone has built a machine similar to the one you would like, and that will give you a realistic idea of the art of the possible. Lightweight commercially- or kit-built machines might work for you, but they also have limitations and you need to go down that route with your eyes open. I'm not saying don't, just be aware of the compromises you are making and decide realistically if that's for you.
Ask questions and listen to the answers - there's a lot of experience on this site from people happy to help.
Just as a stake in the ground, thinking about budget - my roughly 1500x750 cutting area machine that will probably tackle aluminium although only used for wood so far cost around £2500 in materials, ballscrews, guide rails, electronics, etc. It all depends on where and how you source materials and your own machining and assembly skills and facilities.
But good luck - it's great fun building a machine like this! Just be realistic
31-12-2017 #4
You're not going to do it on your budget sorry to tell you this, it's depressing I know and I thought I could build one on a budget and I got a lot of stuff for almost nothing including the frame and it still cost £1500
You need a vfd for the spindles they won't work without it.
I'd say neale's right £2500 is the zone I had to work real hard and had a lot of luck to get mine to £1500 some things are not worth wasting money on like those motors and drivers you linked to other things you can scrimp on get a $5 BOB for now, make your PSU, beg a cheap table to put it on. But don't cheap ass the drivers, the frame, the slides, the motors or the ballscrews as these can;t be upgraded easily without the first ones having little resale value.
Also 10mm pitch ballscrews, don't make my mistakehttp://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
01-01-2018 #5
Sam, Thanks alot for that input, I'm a good listener, and what you said makes sense.
Guys already Iv'e made some some design decisions, I am only going to cut card, I won't bother with any electronics, card will be 2mm thick, work size 300mm x 300mm.............aye, Iv'e already got the kit for that, a good stanley knife and my right hand
I'll spend the other 499 quid on Ibuprofen and beers to aid the repetitive strain syndrome I'll have lol.
o.k Jokes aside, I get it, and I don't believe in reinventing the wheel after receiving good advice so thanks all.
o.k here goes.
my main desire/requirement right now is to cut carbon or GRP plates, and likely never to be above 3mm thick. (though I assume if it were 30mm thick I would just need more tool passes, not a stronger machine) So realistically from what you guys say, if I get sidetracked from that objective to wanting to cut Aluminium and wood etc then I am looking at bigger costs.
(I do want to keep cost down as this is a startup venture with one specific material to cut to my designs).
1. work size will be approx 1000 x 600mm, I am open to change on this for cost effectiveness, the components will not be wider than 250mm square so having a 1000 x 600mm CNC I reckon I can produce 4-6 at a time. but if it were more cost effective to build 2 machines that cut 2 at a time I would do that, not that I intend to, but for example If I only could cut one at a time, then I only need a machine that will cut 250mm square 3mm plunge into carbon fibre plate, so I am open to changing the size depending on cost, if I have to run the machine twice to produce 3 parts, 4 parts,,5,6,7 etc so be it.
So because I would like to batch produce these components, if I could do 20 in a day I'd be happy. and that will determine machine size.
But it seems a waste to limit my machine to just 250mm square 3mm carbon fibre plates if with a little extra grunt and money I could build something capable of more.
2. forget cutting aluminium (I'll have to build or buy another machine in the future.....shame that
3. water cooled spindle,,,,,,,,,,whats a VFD?........variable frequency drive ? i.e speed controller?
4. decent nema motors (even if I oversize them to able to use on another machine).......how do you calculate the nM required, what is the relationship between the force and table size? I guess the longer and wider the ball screw and hardness of materials being cut to travel speed determines the motor force needed? but how do you decide or calculate it,,,,yes I could copy another design for that but is there some rule of thumb?
5. What's a $5 BOB?
6. I already got a Table, it is an old school classroom table, 1" steel legs/frame and a formica type top bolted to it, I can attach my machine to that.
This forum needs a glossary for us noobs ;-)
Thanks for the input guys.Last edited by Heliox; 01-01-2018 at 12:35 PM.
01-01-2018 #6
Can you weld? Or do you know someone who can and will for free. This will save you a lot of money.
You will need slides
https://www.ebay.co.uk/itm/15-1500mm...oAAOSwyi9aJP-x
This is the cheapest I've found them and I have this exact set very happy with them, you will not find them cheaper than this new.
You will need a drive as well, ballscrew is your best choice here Ebay is your friend but expect £250 and maybe some import tax.
3. Variable frequency drive it's a inverter that drives the spindle. Spindles are not running 240v single phase they are 3 phase and need the VFD to drive them you cannot connect a spindle directly to either single phase of 3 phase otherwise you get the magic smoke. Water cooled spindle are much quieter if you need a water pump pay postage I'll send you one for free I have a box of them. £200 for spindle with VFD.
4. Everyone seems to go for 3nm Nema 23's ~£30 a motor, I have 2nm on my machine £20 a motor. You definitely don't want less than 2nm.
5. Breakout board to connect to parallel port on a PC, this means you need a desktop PC to drive the machine but it's the cheapest possible way (Yes even cheaper than arduino)
https://www.ebay.co.uk/itm/Mach3-CNC...AAAOSwhqhaRkJb
Buy 2
Think about how your going to control the machine you can buy Mach 3 £200 or use linuxcnc free I chose linuxcnc ;) You need to generate Gcode for the machine most of us are using fusion 360 for this but there's many ways of doing it depending on the job.
I understand the need to cheap ass it I really do I would never have built my machine if I knew what it would cost lol but I'm so glad I did. The best thing you can do first is learn! Read people diaries ask questions. If the job you have for it is profitable you can probably find someone on here to make them for you and still make money giving you a cnc fund ;)
Don't get put off by the cost because in the end the cost will seem nothing to amount of work you have to put in lol, there's a reason we all take 3-9 months to build our machines the first time it's a lot of work when you include what you have to learn.
But once you've done it you're in a special club for sadists that only members can ever understand lol.
It's also highly addictive ;) Most of us on this site would rather get 2 3m lengths of 25mm Hiwin's with carriages for Xmas than a new Iphone, which is the way it should be to ;
Now I built one I can say you build must start in cad! I thought I could build one without cad I was so wrong lol I was being idle. I could have worked it out on paper but damn it would have be sadistic and expensive with mistakes.Last edited by Desertboy; 01-01-2018 at 01:47 PM.
01-01-2018 #7
1.That's a good size. Big enough to be useful, but not so big that you start to give significant construction issues. It's not really worth going much smaller unless you have to because of lack of space. The finished machine will end up around 300mm bigger than the cutting area in each dimension (give or take a bit).
2. By keeping the size down, you can get reasonable strength again without going to anything too ambitious by way of construction. You might end up with something that can cut aluminium with care.
3. As said, water cooling means that the spindle is quieter, and can run for hours without problem. So can air-cooling, but you need to be a bit more careful about dust management so that it doesn't clog. You are right about VFD. Generally these can be controlled manually via the front panel or connected to your control box for software control of start/stop/speed.
4. There are some spreadsheets on this site which will allow you to calculate the exact motor spec required. However, to be pragmatic about it, the answer for this general class of machine is NEMA23, 3Nm or 4Nm. Might as well go for the more powerful as there is barely any cost difference. Don't go for cheap eBay motors as these are generally high-inductance and for various reasons this is a bad thing!
5. BOB is break-out board, and functionally it is a kind of junction box that takes the connections from your PC parallel port and makes it easy to connect the stepper motor drivers and things like emergency stop buttons and limit switches (for end-of-travel detection). It does a little more than that (like provide isolation between PC and drivers for protection of one from t'other) and might also provide the signals you need to control the VFD but if you think of it as a junction box, you won't be far wrong. There are really cheap BOBs that will do the job. However, they assume that you are using a parallel port on your PC and a lot of modern PCs don't have these although you can add them via an add-on interface card. That brings up questions of Mach3/Windows, or LinuxCNC. That's another whole story but not really one that needs too much thought at this stage. There are other alternatives which complicate the story as well - we'll leave that one for now!
6. You will be astonished at how fast and how violently a decent machine can shake itself around. Even if you are not doing fancy 3D carving (and you will be able to) even things like boring holes involve frequent and rapid direction changes. That table will hold the machine while static but it's going to need quite a bit of bracing to handle dynamic loads.
Keep asking. Don't get upset if you get your leg pulled from time to time. Goes with the turf! But you'll get plenty of useful info as well.
01-01-2018 #8
if you can weld then making a cnc out of steel would be an advantage as welds are stronger than fixing with bolts an nuts, if you do use ally then people tend to bolt them, I think it personal preference, I know you said you have a table to use as a base so you could weld extra supports to brace an sniffen it.
As to regards to designing your cnc in a cad program before you get to building, I’m currently doing it and I’m getting all my demensions off the net, ie rail sizes and block diemensions, so the information is out there just obvious you have to draw each part in your cad program, I’m not sure if you can find them as a open source design and just put them into your design, I’m using solidworks so don’t know if I could attach what I have to help you out design wise. As soon as I’m finished with mine I’ll let you have a look lol
The linear rails are better as they take more load and has massive advantage over the supported rails, there are videos that compare the two if you want to see why, the main thing that made me choose linear rails is there more accurate and have a lot less play the the blocks, again I’m still learning but the price difference it’ll be silly to go cheap on a key parts like rails, ball screws an spindle as there not easy to upgrade in the future.
I hope this helps and looking forward to seeing what you come up with, I’m still along way from getting my build log off the ground
02-01-2018 #9
Sounds good to me.
I'll go watch the videos on the rail comparisons.
re:welding, my only concern is steel is very difficult to weld and maintain high tolerances, for instance creating a right angle between two pieces of steel, after you have prepped and clamped into position, then welded and cooled down, you might end up with 88 degrees instead of 90, most things that doesnt matter, but if you then wanted a true 90 deg out of it you'd have to machine faces.
I think that is why Ali extrusions are desirable as they are made to high tolerance and obviously adjustable to square up.
Maybe there are welded CNC machines on here, I'll take a look out of interest. But unless there are huge advantages I'd be prefer to bolt together, and maybe weld the odd bracket if needed.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
BUILD LOG: New Build 1000x600x200mm (newbie)
By Noplace in forum DIY Router Build LogsReplies: 139Last Post: 21-04-2016, 05:46 PM -
Newbie CNC Build
By JunkieHobbo in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 13-04-2012, 07:41 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM
