Page 3 of 3 FirstFirst 123
  1. #21
    Sorry Clive, my question was about the polished Aluminium side plates on the Gantry being rebated into their bottom plates, is it bolted and welded or just bolted?
    Ok some pics: Click image for larger version.
ID:	23529Click image for larger version.
    The two cross beams are 60x60x5 with 12mm plate welded on the ends then they were machined both front faces & top and bottom also the ends were machined parallel with each other at a local engineers.
    The front plate is ecocast 20mm screwed to the two beams.
    The gantry sides are 20mm rebated into the bottom plate. There are 4x M12 bolts to fix each box section to the side
ID:	23531   Click image for larger version.
  2. The Following User Says Thank You to Clive S For This Useful Post:
  3. #22
    That's a cracking build Clive
  4. #23
    Thanks, I could never have done it without drawing in CAD first and with the help of this forum
  5. The Following User Says Thank You to Clive S For This Useful Post:
  6. #24
    Thanks Clive.
    That for sure looks solid. I think I'll be here a few weeks reading through all the posts
  2. BUILD LOG: New Build 1000x600x200mm (newbie)
    By Noplace in forum DIY Router Build Logs
    Last Post: 21-04-2016, 05:46 PM
  3. Newbie CNC Build
    By JunkieHobbo in forum Gantry/Router Machines & Building
    Last Post: 13-04-2012, 07:41 PM
  4. BUILD LOG: Newbie First Build 3000mm x 1500mm
    By psiron in forum DIY Router Build Logs
    Last Post: 16-07-2010, 11:02 AM
  5. BUILD LOG: Newbie First Build
    By Dr Snuggles in forum DIY Router Build Logs
    Last Post: 10-01-2010, 07:05 PM
