    Wal's Avatar
    Quote Originally Posted by driftspin View Post
    Hi Wal,
    Best wishes to all on this great forum.
    ot. I am not fully aware of commercial pricing.
    Many companies in NL just do B2B.
    Since i am still private they will not take orders or do rfq.
    Since these parts are to be my Y Z carriage mounting plates .. i do want at least half decent quality parts.
    If these plates are to be 150 euros in 6082 or lower strenght and 180 in 7075 .. i rather spend 30 on 7075... it is the weakest link in my gantry..
    I dont want to go to heavy so 50kg gantry is about max.. thinner is lighter... well you know... try to do not OTT and spend money where it matters most.
    Grtz. Bert.
    Hi Bert,
    Totally understand your thinking for the sake of an extra thirty Euros... I've found 7075 to be quite a bit more expensive than the 6082 here in the UK, but hey - maybe I'm shopping in the wrong places!
    In practical terms, it would be interesting to see how much difference to the strength using 7075 would make...
    All the best!
    Wal.
    Sent from my HTC One M9 using Tapatalk
    Just ring any aluminium supplier in the Netherlands they will be able to supply tooling plate, it might not be called ecocast but tooling plate is available everywhere I got it in Lithuania in 10 minutes lol and UK 3 of the 4 suppliers in Leicester could get it next day that I rang.
    None of the suppliers in Leicester had heard the brand name ecocast but they did know tooling plate, ground flat both sides.
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
  4. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  5. #4
    Sometimes known as Mic6 or Mic-6 ;)
  6. The Following User Says Thank You to Davek0974 For This Useful Post:
  7. #5
    Still looking... and doing redesigning.
    Just found out that cnc4you 4nm 23's are some 30mm bigger than my cad model 8)
    Grtz. Bert.
  8. #6
    Ordered the 7075.
    Got it delivered today... it says mic6 printed on the plate :-)
  9. #7
    This is an interesting discussion - if a little old. When I looked up the properties, 7075 seemed to be much stronger (tensile strength), but very little stiffer (elastic modulus still around 70GPa) so I didn't see much point in using it - or have I been fed duff data????
  10. #8
    Wal's Avatar
    Yeah, that sounds right... I bought a few sheets of 7075T6 a while back to make a few bottle openers from - bottle-tops would chew up anything made from 6082. The 7075 still looks perfectly fine years later. Not done a side by side bend test, but there's probably not much between them.
    Some useful info:
    https://www.makeitfrom.com/compare/6...97075-Aluminum
  11. #9
    Thanks for the link..... though I notice there doesn't seem to be any hardness data, which maybe makes all the difference on your beer enabling products :-) I had a bracket out of a Bentley that was made of some such alloy and man was it stiff - quite unlike any ali I've ever touched before.
  1. BUILD LOG: Made of aluminum, Made for aluminum: Would love design critique!
    By gamingan in forum DIY Router Build Logs
    Last Post: 27-06-2017, 11:33 AM
  2. Replies: 3
    Last Post: 28-04-2017, 10:18 PM
  3. Aluminum finish
    By Boyan Silyavski in forum Metal Finishing Techniques
    Last Post: 07-09-2014, 07:32 PM
  4. RFQ: Joint assembly needed making from 7075 T6 billet.
    By dudz in forum Projects, Jobs & Requests
    Last Post: 06-11-2013, 11:26 PM
  5. 7075 Aluminium supplier?
    By m_c in forum Marketplace Discussion
    Last Post: 30-12-2010, 12:27 PM
