    Just ring any aluminium supplier in the Netherlands they will be able to supply tooling plate, it might not be called ecocast but tooling plate is available everywhere I got it in Lithuania in 10 minutes lol and UK 3 of the 4 suppliers in Leicester could get it next day that I rang.
    None of the suppliers in Leicester had heard the brand name ecocast but they did know tooling plate, ground flat both sides.
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 619 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
  3. The Following 2 Users Say Thank You to Clive S For This Useful Post:
    Sometimes known as Mic6 or Mic-6 ;)
  5. The Following User Says Thank You to Davek0974 For This Useful Post:
  6. #4
    Still looking... and doing redesigning.
    Just found out that cnc4you 4nm 23's are some 30mm bigger than my cad model 8)
    Grtz. Bert.
  7. #5
    Ordered the 7075.
    Got it delivered today... it says mic6 printed on the plate :-)
  8. #6
    This is an interesting discussion - if a little old. When I looked up the properties, 7075 seemed to be much stronger (tensile strength), but very little stiffer (elastic modulus still around 70GPa) so I didn't see much point in using it - or have I been fed duff data????
  9. #7
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Yeah, that sounds right... I bought a few sheets of 7075T6 a while back to make a few bottle openers from - bottle-tops would chew up anything made from 6082. The 7075 still looks perfectly fine years later. Not done a side by side bend test, but there's probably not much between them.
    Some useful info:
    https://www.makeitfrom.com/compare/6...97075-Aluminum
  10. #8
    Thanks for the link..... though I notice there doesn't seem to be any hardness data, which maybe makes all the difference on your beer enabling products :-) I had a bracket out of a Bentley that was made of some such alloy and man was it stiff - quite unlike any ali I've ever touched before.
  1. BUILD LOG: Made of aluminum, Made for aluminum: Would love design critique!
    By gamingan in forum DIY Router Build Logs
    Last Post: 27-06-2017, 11:33 AM
  2. Replies: 3
    Last Post: 28-04-2017, 10:18 PM
  3. Aluminum finish
    By Boyan Silyavski in forum Metal Finishing Techniques
    Last Post: 07-09-2014, 07:32 PM
  4. RFQ: Joint assembly needed making from 7075 T6 billet.
    By dudz in forum Projects, Jobs & Requests
    Last Post: 06-11-2013, 11:26 PM
  5. 7075 Aluminium supplier?
    By m_c in forum Marketplace Discussion
    Last Post: 30-12-2010, 12:27 PM
