    I am aiming to do mainly woodworking on my 6040.
    Then get V Carve Pro, as Neale said.
    Regarding Mach4, do a lot of research before spending your money....
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    I use CamBam for all my design work. It is a 2D package which is fine for almost everything you may want to cut out with a 3-axis router. It is easy to learn and use, has a pay-once-get-free-updates-for-life license and there is an active community producing some very useful add-ons including v-carved text.
    You can buy it as a package with MACH3 or, for a low-cost option, the resulting G-code works well on CNClinux software.
    Kit
    CAD and CAM can be separate packages if you want them to be if you want to spread the risk of F360 changing T&Cs (no sign of this by the way). I use a range of CAD software and they all produce IGES files which you can import into F360 and make use of the extensive CAM features.
    Obviously the files are not linked this way and if you spot an issue doing the CAM you have to edit on the CAD program and export again. Rarely happens in practice and well worth it for the F360 CAM features.
    The Vectric stuff is great (I have some myself) but there is a cost so I would do some comparisons with F360 before deciding. By the way F360 only runs on 64 bit so bare that in mind as last time I checked Mach 3 does not so if using that to drive the machine you need 2 PCs or dual boot etc
    Turbocad pro with the CAM and wood working plugin would also be an excellent choice if you search ebay.com you can normally find last years version for 1/3 the price of this years.
    I use fusion now BUT I would highly recommend turbocad and see a time in the near future where I'll buy the latest copy (Mine is 8 years old) and subscribe to fusion as well.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Mach itself will run on 64bit, however the parallel port driver requires 32-bit and nothing newer than Win7.
    I have a spare pc with parallel port on board, free if you collect I'm in Leicester.
    I'm with Kitwn and also use CamBam.
    Before you spend money on CAD software you need to decide why you need it. If it's for 3D work then it's maybe required but for 2.5D work there should be enough CAD in CamBam to cover your requirements.
    That may be true of other CAM software but I don't have experience of those.
    m_c thanks for the correction
    Fusion is great for Hobbyists but the regularity of updates, and FUBARs, combined with a complete lack of genuinely up to date documentation for the current version on any given day leaves me viewing it as an interesting way to add uncertainty to the future of your use of CAD/CAM.
    I used to think Autodesk would at some point skank everyone with a move to subscription but I've now realised they've already skanked everyone into a perpetual Beta Programme with no prospect of a finished product whilst leveraging all the testing and feedback for their subscription products :D
    Thanks guys I'm thankful for the input I will check out vcarve, cambam, fusion360 (free)
    just need to fix my setup atm as nothing is responding for me?
  1. fusion 360 cnc parts
    By charlieuk in forum Fusion 360
    Last Post: 24-05-2017, 02:23 PM
  2. Replies: 6
    Last Post: 23-05-2017, 01:16 PM
  3. Fusion Problems
    By cropwell in forum Fusion 360
    Last Post: 04-03-2017, 07:39 PM
  4. I need advise again
    By habibuzziwa in forum General Discussion
    Last Post: 08-10-2012, 10:08 AM
  5. I need advise
    Last Post: 03-10-2012, 10:50 AM
