    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    F360 only runs on 64 bit so bare that in mind as last time I checked Mach 3 does not so if using that to drive the machine you need 2 PCs or dual boot etc
    Mach itself will run on 64bit, however the parallel port driver requires 32-bit and nothing newer than Win7.
    I have a spare pc with parallel port on board, free if you collect I'm in Leicester.
    I'm with Kitwn and also use CamBam.
    Before you spend money on CAD software you need to decide why you need it. If it's for 3D work then it's maybe required but for 2.5D work there should be enough CAD in CamBam to cover your requirements.
    That may be true of other CAM software but I don't have experience of those.
    m_c thanks for the correction
    Fusion is great for Hobbyists but the regularity of updates, and FUBARs, combined with a complete lack of genuinely up to date documentation for the current version on any given day leaves me viewing it as an interesting way to add uncertainty to the future of your use of CAD/CAM.
    I used to think Autodesk would at some point skank everyone with a move to subscription but I've now realised they've already skanked everyone into a perpetual Beta Programme with no prospect of a finished product whilst leveraging all the testing and feedback for their subscription products :D
    Thanks guys I'm thankful for the input I will check out vcarve, cambam, fusion360 (free)
    just need to fix my setup atm as nothing is responding for me?
    oh on a side note I just seen a thread about the parallel ports and it was mentioned that a parallel port to USB connector will not work... I am confused because the machine came with a Parallel port to USB connector?
    removed and moved to other topic
  1. fusion 360 cnc parts
    By charlieuk in forum Fusion 360
    Last Post: 24-05-2017, 02:23 PM
  2. Replies: 6
    Last Post: 23-05-2017, 01:16 PM
  3. Fusion Problems
    By cropwell in forum Fusion 360
    Last Post: 04-03-2017, 07:39 PM
  4. I need advise again
    By habibuzziwa in forum General Discussion
    Last Post: 08-10-2012, 10:08 AM
  5. I need advise
    Last Post: 03-10-2012, 10:50 AM
