    I haven't fitted greasing fittings to my carriages as it's a PITA with the 15mm Hiwin's. Can I get away with just oiling the rail and then moving the carriages a few times over the oiled area.
    I bought 2nd hand Hiwin and when I first got them they were a little tight but the jig had not been moved in a long time. I added a little synthetic engine oil to the rails and ran the carriages a few times over the oil and because super silky smooth like my clone rail is (Clone rail and carriages were new). I also realised I'll have to strip it down to add greasing points so oiling the rail would save me a lot of hassle.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    The idea of greasing the actual carriage, is it lubricates the passageways and provides lubrication for a good period, plus it helps to flush out contamination. By just oiling the rail, at best you'll get a coating of oil on the balls, and are more likely to get contamination into the carriage.
  5. The Following User Says Thank You to EddyCurrent For This Useful Post:
  6. #4
    Someone posted a link to these 4mm fittings a while back, and I ordered 20 of them. But I haven't checked to see how well they'll work.
    https://www.ebay.com/itm/M4-M20x1-5m...item4d3ad18fb1
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  7. The Following User Says Thank You to Ger21 For This Useful Post:
  8. #5
    Nice one :) exactly what I needed
  9. #6
    Hiwin carriages already come with a grease nipple, at least mine did, but you will struggle to find a fitting for them that does not leak grease everywhere, there seems to be a lot of back pressure from the bearing.
  10. #7
    Recommend lubricate through the oil nipple on carriage,during the working there may have some dust or scarf inside the carriage,and it is possible can clean out part of the tiny dust during the lubrication.
  11. The Following User Says Thank You to bstautomation For This Useful Post:
  12. #8
    Quote Originally Posted by bstautomation View Post
    Welcome to the forum
  13. The Following User Says Thank You to Lee Roberts For This Useful Post:
  14. #9
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Hi and welcome to the forum Fred
  15. The Following User Says Thank You to Clive S For This Useful Post:
  16. #10
    aha,thank you Roberts :)
  17. The Following User Says Thank You to bstautomation For This Useful Post:
  1. FOR SALE: Hiwin rails 15mm with carriages
    By Desertboy in forum Items For Sale
    Last Post: 05-07-2017, 08:05 PM
  2. Greasing Hiwin HG15
    By EddyCurrent in forum Rails, Guideways & Bearings
    Last Post: 14-10-2014, 05:39 PM
  3. RFQ: 7mm Ball on 4mm bar 15mm long (as 1 part) x 50
    By Fletchirwin in forum Projects, Jobs & Requests
    Last Post: 23-01-2014, 10:00 PM
  4. a perfect 90deg joint - 15mm Alu
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 24-02-2013, 01:31 PM
  5. WANTED: Bit OT - 15mm od seamless tube?
    By m_c in forum Items Wanted
    Last Post: 11-07-2012, 09:23 PM
