Thread: Odd 2d pocket behaviour
Hi
still learning Fusion here, long way to go :)
I have two tool paths on a part, simple 2d pockets for a mill.
Both have helix ramps, one works fine - the tool helix's down and then starts the cut, the other helix's down then retracts, lowers and starts the cut??
I can't seem to find out why one retracts after the helix - sort of makes it a bit pointless?
Any ideas?
06-01-2018 #2
Dave
Is the problem hole much smaller in diameter with not much left to cut after the spiral down? Wonder if the tool does not fit when any remaining stock parameters are considered. When the tool retracts does it go to the middle of the hole before plunging ?
06-01-2018 #3
You will have to forgive my ignorance, but does Fusion do CAM ? This is similar behaviour I get with EstlCam generated code. I also get some holes drilled with a proper peck and some holes drilled by peck and full retraction.
06-01-2018 #4
06-01-2018 #5
Don't think so, tool is 8mm, hole one is 50mm round and ok, hole two is 50x40mm and is odd.
The tool seems to spiral down, retract and drop back down, only z axis moves.
Edit...
I just removed "multiple depths" so it now spirals all the way down, full vertical retract and drop then cuts!Last edited by Davek0974; 06-01-2018 at 06:26 PM.
Vectric crazy pocket strategies..
By paulus.v in forum VectricReplies: 5Last Post: 22-08-2017, 10:12 AM -
conect software what do these 4 do, pocket, drilling and profile?
By windows20 in forum Machine Control SoftwareReplies: 5Last Post: 31-08-2016, 03:20 PM -
Noise, Interference, and unexplained electrical behaviour
By g4ghp in forum General ElectronicsReplies: 4Last Post: 24-04-2014, 11:39 AM -
Circular Pocket problem?
By Leadhead in forum Machine DiscussionReplies: 6Last Post: 03-10-2013, 01:05 PM -
Odd PC behaviour
By Wobblybootie in forum General ComputingReplies: 14Last Post: 01-12-2010, 02:32 PM
