    One for the electronic experts - would a pair of resistors in series across the 12V output with values chosen to give 10V at the centre tap point work? All outputs would be 10/12 ths of the input so it would track all intermediate speeds ? If so just 2 cheap components required
    That's a classic Voltage Divider and Yes, it will work provided your circuit can carry enough current to deliver the signal current required (V=IR)
    Do the maths in combination with the input impedance data from the controller manual.
    Remember that sourcing any current from a simple resistor based Voltage Divider will skew the output, you need to know the input impedance and available current to work out the values which will safely give the best result.
    Hence my suggestion of an Op Amp circuit with fractional gain.
    - Nick
    Okay, had a quick look at the data sheets for both the inverter and the controller. OP is quite correct - the controller expects to be supplied a 10V supply from (e.g.) inverter, and will presumably generate a 0-Vref for the spindle speed. What is needed is to reduce the 12V reference voltage to 10V. A simple way to do this would be to place 3 silicon diodes in series with the 12V output from the spindle.
    +12 -------->|------>|------>|------------- +10V In
    Diodes 1N4001, or similar would be good enough and cost pennies each.
    You could put a LM317 regulator inline - with 2V difference between Vin and Vout, it should manage well enough, but it's probably a sledgehammer to crack a nut.
    There is also a AO1 analogue output on the inverter, range 0-10V, but I can't figure out a way to use this to generate a constant 10V output.
    Lives in Plymouth, United Kingdom. Last Activity: 14 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    I would go for the diode solution as well. Even if you buy from Maplin, they're still cheap enough and it's a better solution than resistors. Tweak the calibration as also suggested here (if needed - give or take a few per cent, spindle speed isn't that important) and job's done.
    A fixed 2 Volt drop may be acceptable for the OP's requirements and that's an elegant solution if such is the case, I had Tunnel Vision on an output proportional to the input,
    - Nick
    I'm impressed with the inverter - the manual claims the electrolytic caps within are "wearing parts" and must be replaced after 5 years.
    At least they're honest.
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    That's interesting, I have a couple of 1hp Siemens VFDs which are well over 10 years old and get daily use, standards must be slipping ;-)
    ...or Siemens don't push the limits quite as much as the Chinese? I seem to remember that the HY manual says that you need to re-form the electrolytics if the inverter isn't used for a year, and you should use a variable voltage supply and work up to full voltage slowly. My guess is that daily use is actually better for the caps than letting the thing stand unused for long periods. I try to use 105degC caps for high-power applications rather than the cheaper 70degC versions - maybe Siemens do as well!
    The reason I suggested changing the parameters is this;
    The manual for a Nowforever E100 shows that it uses 12v for the 0-10 input.
    The graph shown in the first post of this thread shows that speed error gets worse as the frequency increases.
    It suggests to me that the upper frequency setting should be adjusted so that at maximum input voltage to Analogue Input 1, the frequency was such that spindle speed was correct.
    Regarding diodes, we used to use this method on reversing roller tables to give a central dead band for the operators, but on some of the newer drives this did not work as planned.
  1. How to connect 2.2KW Inverter VFD?
    By Tenson in forum Spindles & Drive Motors
    Last Post: 13-07-2020, 01:47 PM
  2. Just blown up my inverter
    By Lodds in forum Generic Chinese Spindles
    Last Post: 01-01-2018, 06:49 PM
  3. 2.2KW 3HP Inverter help
    By adamh in forum Spindles & Drive Motors
    Last Post: 31-07-2015, 09:21 AM
  4. eBay: Denford Novamill SmartStep Control Board + Spindle Board
    By danielbriggs in forum Items On eBay UK
    Last Post: 30-05-2013, 06:52 AM
  5. Teco inverter
    By Ronaldo9 in forum Spindles & Drive Motors
    Last Post: 20-01-2013, 01:42 PM
