    What you say is correct but;
    1. Regardless, the vfd diagram does show the input connected to 12v
    Again, we are interpreting a Chinglish manual (or diagram, in this case) so there is a bit of guesswork here! The given diagram shows a pot supplied with 12V. If the idea is that the pot is uncalibrated and you use it in conjunction with the VFD display, then this is fine - in effect, it just reduces the rotation of the pot spindle to go from zero to full. Ditto, I guess, if the pot has a calibrated scale associated but again you won't use the full pot travel.
    Slightly different situation where the analogue input is driven from an external source, although it's a pity that the BOB or whatever doesn't regulate the DC input to ensure that the output range is correct.
    Guys,
    With the right pot the source voltage is close to irrelevant so long as you can't blow the VFD input with the output.
    Instead of arguing semantics why not posit a functional solution to the problem as it stands.
    Offsetting voltage with diodes chops off the bottom of the range BTW ;-)
    - Nick
    No it doesn't. Read my post - it's reducing the Vref voltage from 12V to 10V. The controller's charge-pump will then generate a voltage proportional to the M-S ratio of the demand vs Vref - from 0v to 10v.
    It is a functional solution.
    I didn't think the OP had a "pot" - if he did, then the solution would be to introduce a positive-side static resistance, e.g. 2k on top of a 10k pot, which would give a sufficient offset from the 12V reference voltage. But that's not the design case here.
    Re. the chop-off. Nope, what you have interpreted is the insertion of the diode chain into the Ain1 input, that's not what I posted.
    So the BOB will function properly with 10V input rather than 12V?
    Bonus, you've fixed it!
    Nice one!
    The BoB requires a 10V ref input. The implementation is flawed by driving that with a 12V reference.
Name:	Screen Shot 2018-01-08 at 23.34.15.png
    I know it would be a bit more faff but if it really needs 10V in from a 12V supply I'd put a regulator in ;-)
  1. How to connect 2.2KW Inverter VFD?
    By Tenson in forum Spindles & Drive Motors
    Last Post: 13-07-2020, 01:47 PM
  2. Just blown up my inverter
    By Lodds in forum Generic Chinese Spindles
    Last Post: 01-01-2018, 06:49 PM
  3. 2.2KW 3HP Inverter help
    By adamh in forum Spindles & Drive Motors
    Last Post: 31-07-2015, 09:21 AM
  4. eBay: Denford Novamill SmartStep Control Board + Spindle Board
    By danielbriggs in forum Items On eBay UK
    Last Post: 30-05-2013, 06:52 AM
  5. Teco inverter
    By Ronaldo9 in forum Spindles & Drive Motors
    Last Post: 20-01-2013, 01:42 PM
