No it doesn't. Read my post - it's reducing the Vref voltage from 12V to 10V. The controller's charge-pump will then generate a voltage proportional to the M-S ratio of the demand vs Vref - from 0v to 10v.
It is a functional solution.
I didn't think the OP had a "pot" - if he did, then the solution would be to introduce a positive-side static resistance, e.g. 2k on top of a 10k pot, which would give a sufficient offset from the 12V reference voltage. But that's not the design case here.
Re. the chop-off. Nope, what you have interpreted is the insertion of the diode chain into the Ain1 input, that's not what I posted.Last edited by Doddy; 09-01-2018 at 12:19 AM.
09-01-2018 #2
So the BOB will function properly with 10V input rather than 12V?
Bonus, you've fixed it!
Nice one!You think that's too expensive? You're not a Model Engineer are you? :D
09-01-2018 #3
09-01-2018 #4
I know it would be a bit more faff but if it really needs 10V in from a 12V supply I'd put a regulator in ;-)
How to connect 2.2KW Inverter VFD?
By Tenson in forum Spindles & Drive MotorsReplies: 20Last Post: 13-07-2020, 01:47 PM -
Just blown up my inverter
By Lodds in forum Generic Chinese SpindlesReplies: 32Last Post: 01-01-2018, 06:49 PM -
2.2KW 3HP Inverter help
By adamh in forum Spindles & Drive MotorsReplies: 8Last Post: 31-07-2015, 09:21 AM -
eBay: Denford Novamill SmartStep Control Board + Spindle Board
By danielbriggs in forum Items On eBay UKReplies: 0Last Post: 30-05-2013, 06:52 AM -
Teco inverter
By Ronaldo9 in forum Spindles & Drive MotorsReplies: 9Last Post: 20-01-2013, 01:42 PM
