    Bigger than my StarMill (160x100!). Height isn't a massive issue for me (at least not as yet), but 200mm would be an aim. X/Y = around 600x400 was my goal.
    Only the crazy people go vertical! Actually, it's something I had just started to think about - I know Dean here has done this in the past. That might be the next machine.
    (assuming you mean square across the Y-Axis) Yes, a beam across the top, with gusset plates to hold square (sorry, the design is obviously incomplete - more to get the concept right in my mind before burning hours on Fusion 360).
    Yes, more steel to be added yet. As above, this is just a basic geometry sanity check.
    That's exactly why I posted this. Placing the spindle where I did I'm very conscious that it's putting a large force on the rails. Having said that, better and brighter people than me have suggested that the rails are more than strong enough for anything a small machine like this is likely to throw at them, and Dean's earlier comment re. most mills - yeah - they'll place a similar cantilever load on the rails as well.
    Hi doddy,
    What is your main problem with exiting 6040 designs?
    I feel like the " lean back " gantry design is most space saving.
    Do you think 20 mm alu gantry sides will cover your rigidity needs?
    http://www.mycncuk.com/showthread.php?t=11610
    like that one... but a bit smaller.
    Grtz Bert.
    Doddy's Avatar
    Quote Originally Posted by driftspin View Post
    Hi doddy,
    Significantly - I want to do as much of the build myself, and (to an extent) I can work with steel. Having said that there's a recent threads that show some very enterprising use of hand tools (though throwing a woodworking hand held router through 20mm of alu would certainly be different to what I'd normally use it for). The design (once I understand it!) is something that I can build with the equipment that I have. To some extent there's a certain curiosity value as well.
    For cost... steel is the cheaper way to build.. there is a catch though.. steel is not easy to get straight/flat enough to mount linear rail directly.
    Did you decide on square or supported rail?
    Do you have access to tools to get the steel flat level and straight ?
    If not.. epoxy is a solution... but not very easy to do.. and not cheap.
    Grtz Bert.
    Grtz Bert.
    what about this one?
    http://www.mycncuk.com/showthread.php?t=11152
  1. BUILD LOG: Desktop size steel welded router 3 axis
    By Tom J in forum DIY Router Build Logs
    Last Post: 28-03-2017, 09:36 PM
  2. building with steel tubing pre-welded plates with holes doable?
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 14-09-2016, 03:26 PM
  3. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  4. FOR SALE: Strong steel welded base with ground flat surface.
    By black5f in forum Items For Sale
    Last Post: 14-01-2012, 07:20 PM
  5. Bench Top Mill
    By Wobblybootie in forum Milling Machines, Builds & Conversions
    Last Post: 04-06-2010, 06:57 AM
