Thread: Milling Aluminium - too fast?
Gary,
With a perfect machine, yes. Calculators will assume industrial machine quality, power, rigidity and spindle TIR plus near perfect lube & chip clearance, an air nozzle on the cutter and the occasional dab of WD is usually a big help on small cutters in aluminium jobs.
I'd suggest you CAM your job with those settings and then run a test, start off with the feed reduced somewhat on your controller, 60% or so, and see how it goes, if it's running smoothly you can move towards 100% feed in steps, some jobs will run faster, some slower, keep a work book with a section logging the ideal settings for the cutters and materials you use.
10-01-2018 #2
Hi Nick,
Yes, all that makes sense. I have a tin of WD40 by the cnc. I'll start at 25mm/min as you suggest and see how I go from there. I have a pack of 10x1mm end mills so I should be able to get to the end of the job :)
Gary
Milling aluminium advice needed
By zxrjohn14 in forum General DiscussionReplies: 8Last Post: 08-11-2017, 02:18 PM -
RFQ: Milling aluminium badge
By Lure in forum Projects, Jobs & RequestsReplies: 0Last Post: 20-04-2017, 05:35 PM -
RFQ: 40x40x3mm aluminium plate milling
By Doub in forum Projects, Jobs & RequestsReplies: 1Last Post: 01-03-2017, 12:11 AM -
Milling Sheet Aluminium
By p1lts in forum Metalwork DiscussionReplies: 8Last Post: 08-03-2014, 12:23 AM -
6082 aluminium milling directions
By dudz in forum Metal Finishing TechniquesReplies: 2Last Post: 16-02-2014, 10:42 AM
