Thread: Cutting Melamine faced chipboard
Whether you do it in one pass or two (onion skin) depends on the size of the part, and the quality of your vacuum hold down. (you do have a vacuum table, right?)
Do NOT climb cut, as it will leave a rougher edge. Conventional cut always with melamine (and most wood products).
Feedrate of 15-18m/min, and 16,000-18,000 rpm.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
15-01-2018 #2
[QUOTE=Ger21;98845]Whether you do it in one pass or two (onion skin) depends on the size of the part, and the quality of your vacuum hold down. (you do have a vacuum table, right?)
Gerry
Thanks for the reply. Invaluable knowledge and massively appreciate the advice.
Yes I do have a vacuum table (sorry cant find spec...) and am machining large parts (kitchen carcass panels). Had spindle speed about right but feed rate less than half what you are suggesting
one last question (sorry) regards cutting direction - will I gain anything (mainly cutter lifespan?) from running an initial offset 'climb' pass before doing final dimension profile as a conventional (melamine + most wood materials) ?
thanks again in advance
Nicko
16-01-2018 #3
Imo, no. Conventional cutting will give better tool life.
By doubling the feedrate, your tool life should also nearly double.Gerry
16-01-2018 #4
The reason that some people do a climb pass first, followed by conventional, is this.
At high chip loads like this, the cutting forces are pretty high, and with a conventional cut, will tend to pull the tool into the part, resulting in a slightly undersized cut.
This can also happen when onion skinning. The first pass will pull the tool into the material, but the final pass will be more accurate, and leave a small lip on the bottom of the part.
By doing a climb cut first, the tool is actually pushed away from the part, which leaves a small amount of material for the final, conventional cut.
But the climb cut won't cut as clean, especially as the tool starts to wear, so it may leave chips that won't be removed on the final pass.Gerry
16-01-2018 #5
16-01-2018 #6
One of the best methods to achieve a full depth cut is to use a trochoidal machining operation.
CamBam has an excellent plugin for such cuts if your current software does not.; http://www.atelier-des-fougeres.fr/C...choPocket.htmlLast edited by EddyCurrent; 16-01-2018 at 12:05 PM.
16-01-2018 #7
There's no need for trochoidal toolpaths when cutting wood, and certainly not when cutting cabinet parts.
Gerry
CNC Vinyl Cutting
By Leadhead in forum Workshop & EquipmentReplies: 11Last Post: 24-03-2016, 09:09 PM -
working with only low grade chipboard
By steven in forum Woodwork DiscussionReplies: 0Last Post: 28-11-2015, 12:33 PM -
FOR SALE: Pair of Thorex Nylon Faced & Body Hammers in size 32mm & 44mm
By Solihull1 in forum Items For SaleReplies: 0Last Post: 14-08-2014, 07:07 PM -
Cutting Ply/MDF
By Leadhead in forum Wood Finishing Tips & TricksReplies: 3Last Post: 02-10-2013, 01:59 PM -
Cutting Fluid
By Web Goblin in forum Swarf & Chip ManagementReplies: 4Last Post: 12-01-2013, 09:31 PM
