    Quote Originally Posted by battwell View Post
    does probing work correctly as a separate macro? (not in m6)
    Yes if using Cslabs macros. The problem is with Mach rather than Cslabs but the workaround is to use Modbus and talk directly to the controller rather than going thru Mach.
    Bit fiddly for most but to the man with a DUZZIT Simplizzzz.
  2. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  3. Quote Originally Posted by JAZZCNC View Post
    does it capture exact step output the probe was hit on (like mach with parallel port does) and uccnc now does after a bit of nagging?
    i presume the problem is with their plugin . are they going to fix it?
    i havnt tried a csmio myself but i like to know each ones real life capabilities. (same question i forgot to ask re acorn too)
    Lives in Plymouth, United Kingdom. Last Activity: 2 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I'm using something like Mach3 version .028 and that works fine with the CSLabs macro for touch-off and M6start/end. When I tested the touch-off mechanism, I was getting +-1 microstep repeatability, which is about .03mm on my router. CSLabs say that they are monitoring the probe input in their firmware so there is no Mach3 involvement at that point.
    Even when Mach3 and the CSLabs firmware were still in development they just stood and shouted at each other - "It's all your fault!" Nothing is going to happen now. Looks a bit like CSLabs used an undocumented mechanism in Mach3 which Mach3 then changed after about v .028.
  5. The Following 2 Users Say Thank You to Neale For This Useful Post:
  1. RFQ: Semi automatic welding system Linear beam control system
    By richway in forum Projects, Jobs & Requests
    Last Post: 24-01-2017, 08:54 PM
  2. FOR SALE: Various tooling
    By millietess in forum Items For Sale
    Last Post: 12-01-2015, 10:00 AM
  3. FOR SALE: tooling for sale
    By davy in forum Items For Sale
    Last Post: 10-11-2012, 11:37 PM
  4. Tooling
    By p1lts in forum Tool & Tooling Technology
    Last Post: 11-10-2011, 08:14 PM
  5. HSK Tooling
    By Dairsie in forum Tool & Tooling Technology
    Last Post: 02-09-2011, 10:07 PM
