25-01-2018 #22
~It looks like that board has the facilities to control the spindle with Mach3, but they are not wired in. at the bottom right on pic 4, the board is marked C (Com) NO, which is a spindle relay connection and 0-10v GND, which is the analogue voltage to control speed. I would leave it alone until you have the box working with manual spindle control. Then we can look at the box wiring.
I would not recommend a factory reset on the VFD as you would have a hell of a lot of parameters to sort out. You have probably just taken it off manual control.
The Following User Says Thank You to cropwell For This Useful Post:
Fill in my knowledge gap :)
By Davek0974 in forum CamBamReplies: 50Last Post: 02-02-2017, 02:55 PM -
Power supply understanding
By smeg up in forum General ElectronicsReplies: 4Last Post: 10-02-2015, 07:07 PM -
FOR SALE: Heavy Duty Ballscrew setups with Bearing, Ballnut - Price drop 04/07 - £100
By dynamis_dk in forum Items For SaleReplies: 1Last Post: 14-07-2014, 03:28 PM -
Understanding the bearing block
By Rogue in forum Rails, Guideways & BearingsReplies: 10Last Post: 28-08-2011, 03:14 PM -
Some great DIY clamping setups
By Yohudi in forum Computer SoftwareReplies: 2Last Post: 22-01-2009, 06:54 PM
