Thread: 3040 and Hardwood
17-01-2018 #1
Having experimented on some pine I am now using some hardwood - not sure what sort - as used in hardwood window frames I believe.
I have a 3040 with a 6mm down cutting 2 fluted spiral cutter.
My question is around feed rates and depth of cut etc.
I understand that for a down cutter I should limit the depth of cut to something less than the diameter of the cutter - that's all fine but I find that if I try to cut 4mm it seems to struggle a little and the spindle appears to 'snatch' from time to time.
I am currently limiting the depth of cut to 1mm and I am using a feed rate of 75 in order to give the least stress to the tool etc.
However, this means that to cut a 55mm square pocket 33mm deep it is going to take over 5hrs to complete.
Is this normal and to be expected or am I out by an order of magnitude?
What sort of feed rates / depths should I hope to be achieving when cutting hard wood on a machine like this with the bit that I have?
If this is the way that it is with this kind of machine then I can live with that - I just don't want to take 3 days to cut something that I really should be turning out in 30 minutes!
Thank you in anticipation!
Richard
17-01-2018 #2
i wouldn't use a down cutter to cut a pocket as you are pushing all the chips downwards and recutting them. this isn't going to help at all. I would use an upcut tool and i would run at about 18000rpm and 3000mm/minute with 3mm doc at least
18-01-2018 #3
Thank you very much for that.
I was using a down cutter as the wood would tear at the surface when using an up cutter.
Perhaps I should start the pocket with the down cutter for a few mm then switch to the up cutter for the rest of it?
My max spindle speed is 8000rpm and my cutter 6mm so I run at max rpm and cut 3mm with a feed rate of around 200mm/minute at present - should I be going a lot quicker?
The only reason that I have not gone quicker is that I worry about damaging stuff. I will try shallow cuts at higher speeds to see how it goes. The only real feedback that I have are the various noises that the cutting process makes - many suggest that is how one can tell if things aren't right. Unfortunately I lack the experience required to know what I am listening to!
NEW MEMBER: Need Help with my new CNC 3040 Machine.
By SMG11 in forum New Member IntroductionsReplies: 0Last Post: 27-09-2017, 12:14 AM -
RFQ: Can anyone profile 19mm hardwood - Preston, Lancashire
By ngwagwa in forum Projects, Jobs & RequestsReplies: 0Last Post: 13-10-2016, 09:49 PM -
best hardwood for first 3d milling attempt and end grain vs side grain
By mark84 in forum General DiscussionReplies: 11Last Post: 01-01-2015, 08:13 PM -
Hardwood CNC from wood on a budget, Possible?
By Hopey in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 16-11-2014, 07:03 PM -
Hardwood Supliers?
By Stickio in forum Marketplace DiscussionReplies: 3Last Post: 06-01-2011, 11:21 AM
