Thread: hybrid steppers
Sorry I bothered to offer an opinion. Seems you have an expert here who knows all the answers!
It didn't know that "it must be driven at 70VDC and 4.5A" - that must be a universal truth I wasn't aware of. Sounds as if it will be a hell of a beast. Motors as big as the machine itself.
18-01-2018 #2
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
02-02-2018 #3
Thanks all for the advice it's helped a lot in my research.
Hi George, it was always the intention to convert as the first project been fun machining the mounts for the CNC conversion on it. Yes i was aware of you plans for the kit but quite enjoying the process of the conversion.
Think i've come to the thinking of nema23 3Nm steppers on the x-y and Nema 34 4Nm on the Z, C5 1605 ballscrews on all axis with double ballnut i'll direct drive to start of with to to see how it goes may change to being belt driven in future from Zapp. Leadshine 808 or 828 stepper drivers. Intention is to run LinuxCNC.
Does that sound like a sensible approach?
Thanks in advance
Rob
02-02-2018 #4
I have steppers with encoders fitted to the shaft on my lathe. The real benefit is when you reference off the switches at power up they repeat to 0.00mm every time, so no need to touch off at the beginning of the day to account for the error in the switch. And as the spindle is encoded too, threading.
3 axis lathe/mill hybrid design.
By GordonFreeman in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 08-02-2017, 01:05 AM -
BUILD LOG: Hybrid Mill Design
By Chaz in forum DIY Router Build LogsReplies: 28Last Post: 03-12-2015, 11:31 PM -
Hybrid Stepper Servo
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 08-06-2015, 12:41 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
Hybrid gantry
By routercnc in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 17-04-2012, 08:09 PM
