Thread: hybrid steppers
All very true. more speed less torque. The torque however is more important at the low speeds for acceleration and deacceleration purposes. When you are steady state, you should be ok if you do not want to be running at high rapid speeds.
2.5mm leadscrews would be a waste of time imo. A CNC conversion would need to be run on ballscrews and those are easy to find in 5mm pitch.
You can of course still gear it 1:1 through a belt to retain the handles. I know I used them shitloads on my kneemill conversion.
It all comes down to personal preference.
The voltage you run your motors on will largely depend on your drivers too. I think my original set of drivers from cnc4you disliked being run at 70V so had to get a 48V supply.https://emvioeng.com
3 axis lathe/mill hybrid design.
By GordonFreeman in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 08-02-2017, 01:05 AM -
BUILD LOG: Hybrid Mill Design
By Chaz in forum DIY Router Build LogsReplies: 28Last Post: 03-12-2015, 11:31 PM -
Hybrid Stepper Servo
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 08-06-2015, 12:41 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
Hybrid gantry
By routercnc in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 17-04-2012, 08:09 PM
