Page 4 of 15 FirstFirst ... 2345614 ... LastLast
  1. #31
    So iv moved the motor as JAZZCNC suggested. Im pretty happy with the whole gantry design now so iv started figuring out where im gona put all the nuts and bolt. The whole thing is held together with about a million M5 screw! Takes bloody ages to figure out where they need to go. But id rather do it now in CAD where its easy to move things around, rather than during the build where mistakes could be costly.
    Iv also been thinking about Z axis alignment, both spindle to the axis, and the axis to the machine bed. For spindle to axis measurement I plan to use the same method I used to align my lathe head stock. Its called rollies dads method. Probably massive overkill for this aplication, but its easy to do so why not. Rotation adjustments about the X axis will be made using shims, and Y axis by just roating the spindle by hand and some oversizes holes in the spindle mount.
    For measurement of alignment of the Z axis to the bed i will use a this DTI method.
    Adjustment will be achieved with shims between the stationary Z axis plate and the X axis plate, plus two M3 leveling screws though small blocks shown in the attached image. The two screws are just over 100mm apart, and m3 screws are 0.5mm pitch. This gives me 0.3 degree adjustment per turn. I can lock the leveling screw when the axis is allied, and hopefully I will be able to remove and replace the Z axis if needed without the need to realign anything.
Name:	Z axis alignment.PNG
  2. #32
    So i'm finally ready to order steel and aluminium for the frame.
    Can anyone recommend suppliers in the Manchester area.
    Im currently looking at ordering only from Aluminium Warehouse and Austen Knapman.
  3. #33
    I use Aluminium warehouse, i have heard various stories about them but i still cant find anyone better/cheaper
  4. #34
    ASC metals in lincoln usually knock spots off AW
    http://www.ascmetals.com/
  5. #35
    I have used Forward Metals for small purchases of Ali, and they seem good. https://www.forwardmetals.co.uk
  6. #36
    So after 6 months my CAD models are starting to turn into a CNC!... Slowly....
    The design has changed a bit, but the concept is mostly the same.
    I went with aluminium flat bar rather then cast plate in the end. Very quickly learned that was a bad idea! Flat bar is very far from flat!
    Managed to get everything moving freely so far despite the not flat bar using plenty of shims to level things up. First project when this thing is up an running will be new cast aluminium plates.
    So far I have the gantry carriage and ball screw all made and assembled. Made my own ball screw end supports from 50x50 aluminium bar with angular contact bearings, and bored out and threaded the HTD pulley to replace the lock screw. Everything moves freely and feels rock solid, so very happy with the result.
    Sick of drilling and tapping holes now.
  7. #37
    As I slowly edge closer to the electronics step, I was wondering why we have to over spec a switch mode power supply.
    The stepper drivers we use limit the current to the motors, so why do we need to make sure we choose a power supply that can supply say +20% more current? Surely a driver set to say 2A will only draw 2A from the PSU?
    I'm sure there is a very logic explanation.
  8. #38
    Quote Originally Posted by diycnc View Post
    Hi diycnc,
    Why not build one yourself.
    It is only 5 orso electrical parts.
    Grtz Bert.
  9. #39
    Well, there's a very technical explanation! Actually, the stepper driver does not quite limit current to the nominal value. In fact, it's often unclear what that nominal value means anyway - peak current? Average current? So the value that you set the stepper driver to will be somewhere near the maximum current drawn from the PSU but not necessarily exactly the value you expect. The other problem is that the stepper driver doesn't actually supply a steady current over the whole pulse, but chops it alternately on/off so that the average is around the desired value. So peak current draw might be higher than expected during the pulses, even if the average is around what you would expect. The SMPS must be able to cope with these short-duration pulses without going into "overload" when it might shut down altogether for a brief period, until the "overload" has gone away. This can be pretty catastrophic for the machine overall and losing steps might be the least of your problems. Hence the need to over-spec a SMPS just to make sure that it never goes into current-limiting or overload mode. I would be worrying if the SMPS is only capable of supplying 20% over nominal current - doesn't seem like much headroom to me. That's why the usual advice (even from people like Leadshine who should understand these things) is to use a "linear" power supply which is very tolerant of pulse current overloads.
    This is a bit of an over-simplification, but the fact is that the current draw is very "peaky" and not steady, you are adding together the loads of multiple drivers without any idea of whether their pulse loads will occur simultaneously or not, and you have a power supply that is not capable of handling overloads gracefully. A linear PSU will be heavier, probably larger, more expensive - but more reliable. And they're easy to build - there are several "how-to" threads on the forum. If you go SMPS, over-spec the rating to make sure!
  10. #40
    The other option might be to add a decent size capacitor (maybe 4700...15,000uF) on the output of the SMPS to deliver short term current pulses without tripping the protection. I say "might" because some wimpy SMPS's are just so wimpy that they find it difficult to start up into a large capacitive load, so you'd be b******d from the start. However some do have a "soft start" provision that avoids this and such an approach has got me out of a hole once or twice before.
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. Replies: 4
  3. what router can i use with openbuild ox gantry router?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 13-08-2015, 01:40 PM
  4. eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
    By Deuce_Coupe in forum Items On eBay UK
    Last Post: 16-07-2014, 11:46 AM
  5. Woo, my first 'proper' part!
    By craigrobbo in forum Woodworking Project Showcase
    Last Post: 05-08-2012, 02:51 PM
