    What's the orientation of the sections you're joining? Do you have plates/brackets? (a pic or drawing might help) Either way, 4 x M5's sounds a bit light duty to me, do you have room to go up in diameter? Properly done with the correct surface preparation and curing, epoxy can give a very strong bond - seems to work OK in aeroplanes :-)
    I'm not in the workshop at the moment, but take a look at the pic in post 36.
    Agree 4 x m5 isn't enough, and I dont think there is room to go up in diameter. The existing bolt holes are a little too close to the side walls to go up in size.
    Will try some thin slow setting epoxy on a test piece befor I apply to the frame
    Quote Originally Posted by diycnc View Post
    Will try some thin slow setting epoxy on a test piece before I apply to the frame
    From the pic. and the few screws that are visible it looks like there might be a bit of room to go larger - but then again it's not a close-up, so do check it. If you're using slow setting epoxy do check the manufacturers curing instructions. Araldite Precision for instance cures with better strength at a slightly elevated temperature - as well a a lot quicker. And remember that once it sets you can't adjust stuff any more - so make sure everything gets properly lined up!
    You are always going to have this problem even with larger bolts unless the holes are reamed and a very close fit to the bolts. ie Sholder bolts. It will be to a lesser degree because you'll have more torque with larger bolts but still it could move. Epoxy will help but only upto a point, it certainly won't hurt until you come to take it apart again or decide to weld it up, then it will be a bitch to get off.!!
    Don't you know anyone with a welder.? it will take 20Mins max to weld those few pieces together and it will be so much stronger. Forever.!!
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. Replies: 4
  3. what router can i use with openbuild ox gantry router?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 13-08-2015, 01:40 PM
  4. eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
    By Deuce_Coupe in forum Items On eBay UK
    Last Post: 16-07-2014, 11:46 AM
  5. Woo, my first 'proper' part!
    By craigrobbo in forum Woodworking Project Showcase
    Last Post: 05-08-2012, 02:51 PM
