Thread: First Proper CNC Router
I've gone with common sensors for limits and homing plus soft limits. Sooooo easy in LinuxCNC. I have a low limit switch on my Z axis, but that's because on my design there's a crash risk with the gantry ends if it gets too low. There is a soft limit as well so it's really belt and braces.
In practice you should never need limit switches to prevent a crash as long as you have the soft limits set correctly and always home the machine before you do anything else after switching it on.
BUT. There may be a risk if you have a pendant for manual control of the machine which does not operate through the controlling software and therefore moves the machine without the software knowing. I think this is possible with some of the cheap Chinese break-out boards and is a train-wreck waiting to happen for the blissfully ignorant.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
By SweetAs in forum New Member IntroductionsReplies: 27Last Post: 16-02-2019, 12:06 PM -
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
what router can i use with openbuild ox gantry router?
By davejavu123 in forum OpenBuilds OX CNC MachineReplies: 5Last Post: 13-08-2015, 01:40 PM -
eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
By Deuce_Coupe in forum Items On eBay UKReplies: 0Last Post: 16-07-2014, 11:46 AM -
Woo, my first 'proper' part!
By craigrobbo in forum Woodworking Project ShowcaseReplies: 29Last Post: 05-08-2012, 02:51 PM
