Thread: Floating Tap Holder.
24-01-2018 #11
Ah so! Thanks for clearing this up.
So I will bore out a blank R8 to fit a parrallel shank ER20 holder. Fit a drive pin and spring to bias the holder at 50% of the slot. Then use the square ER20 tapping collets.
Seems like a plan
24-01-2018 #12
Sounds like a plan!
Ensure your materials are hard enough and well lubricated enough to avoid galling, making the pin square with soft corners and using a Moly lube on the sliding areas will help,
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
12-04-2018 #13
Floating tap holders, aka Tension/Compression Tap Holders are the perfect solution when you need to tap a hole. Bridging the synchronization gap between toolhodler and Z-axis feed, the spring mechanism compensates for the minute acceleration.
Factory Automation
Knife holder
By eurikain in forum Woodworking Project ShowcaseReplies: 6Last Post: 25-08-2016, 11:30 PM -
Floating Head for 3020
By iBeta in forum Chinese MachinesReplies: 6Last Post: 29-02-2016, 10:31 PM -
I want to adapt 4x4 CNC for plasma. Do I need a floating head or THC?
By marbles in forum Plasma Table MachinesReplies: 3Last Post: 28-11-2015, 08:07 PM -
Plasma floating head...
By Davek0974 in forum Plasma Table MachinesReplies: 27Last Post: 01-01-2015, 01:52 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
