Thread: Floating Tap Holder.
Thanks James but have you seen the price!! Over 100 per tap size. There are tapping collets available (Standard ER collects with a squarenhole at end to fit specific taps) at about a quarter of the price. Trouble is the collet holders are not available in R8. Question still is how do springs allow the tap (held rigidly by the collet) to float in the holder.
They have to be able to float in all 3 axes but still apply torque to the tap?
How are these floating holder designed?
24-01-2018 #2
No they don't.
Floating tap holders assume the machinist/CAD/CAM Monkey is competent enough to align X and Y and only float in Z, this is to prevent breakage when a machine's Z feed doesn't perfectly match the required movement for the tap to maintain neutral tension.
Floating reamer holder requirements differYou think that's too expensive? You're not a Model Engineer are you? :D
24-01-2018 #3
Ah so! Thanks for clearing this up.
So I will bore out a blank R8 to fit a parrallel shank ER20 holder. Fit a drive pin and spring to bias the holder at 50% of the slot. Then use the square ER20 tapping collets.
Seems like a plan
24-01-2018 #4
Sounds like a plan!
Ensure your materials are hard enough and well lubricated enough to avoid galling, making the pin square with soft corners and using a Moly lube on the sliding areas will help,
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
Knife holder
By eurikain in forum Woodworking Project ShowcaseReplies: 6Last Post: 25-08-2016, 11:30 PM -
Floating Head for 3020
By iBeta in forum Chinese MachinesReplies: 6Last Post: 29-02-2016, 10:31 PM -
I want to adapt 4x4 CNC for plasma. Do I need a floating head or THC?
By marbles in forum Plasma Table MachinesReplies: 3Last Post: 28-11-2015, 08:07 PM -
Plasma floating head...
By Davek0974 in forum Plasma Table MachinesReplies: 27Last Post: 01-01-2015, 01:52 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
