Thread: cnc spoilboard
    HDPE is on the soft side and not good for tapping, so clamping parts down if you use this methods not good to be very good.
    Quote Originally Posted by Dean jeffery View Post
    Is trespa waterproof so I can use coolant? Looks hard to find
    Sent from my SM-N910F using Tapatalk
    Quote Originally Posted by Leadhead View Post
    Searching also Silvans phenolic paper. Any sources of 12/15 mm minimum 500x500 gratefully received.
    In uk it's called Tufnol and it's also very expensive. Often used for making Jigs etc because very stable and easily machined. Thou it's dusty stuff to machine covers everything in yellow layer of fine abrasive dust.
    https://www.directplastics.co.uk/tufnol-sheet
    Quote Originally Posted by dfox1787 View Post
    Yes it is. Often used in swimming baths for cubilcles etc. I came across job lot that from warehouse clearence that had been sat outside over 12months and it's fine.
    I've used whale tufnol good but not as good as the trespa
    I'm thinking aluminium spoilboard might be best for me when I'm using coolant. I'd consider another tslot bed on top on my current one but it's expensive. I need something I can surface as well.
  1. Spoilboard Surfacing - What tool(s) do you use?
    By Mad Professor in forum Tool & Tooling Technology
    Last Post: 12-01-2013, 11:55 AM
