Thread: Cnc wiring!
25-01-2018 #2
0.75mm 4 core CY cable, you need CY normal 4 core is a big No due to interference. Wire colour is irrelevant and you'll find CY you get 3 blacks wires and an earth. It's very easy to work the wiring out it doesn;t matter how you wire it to the motor the end you wire to the drivers twist 2 wires and try to turn you ballscrew if you feel resistence you have matched pair if not try a different combination. When you have a matched pair the other pair must be matched wire them to the drivers. If the motors go the worng way invert the pin in Mach3/linuxcnc.
https://www.ebay.co.uk/itm/ALL-CY-CA...EdeT991FfFPUNw
Search for companies local to you it's not hard to source cheaper than this.Last edited by Desertboy; 25-01-2018 at 12:17 PM.
VFD to USB WIRING ????
By Stucncusb in forum Spindles & Drive MotorsReplies: 0Last Post: 23-08-2013, 07:06 PM -
cnc wiring
By crossleymarko in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 09-04-2012, 09:35 PM -
wiring help
By deannos in forum Motor Drivers & ControllersReplies: 3Last Post: 08-06-2011, 02:20 PM -
help me for wiring
By ali hedi in forum General ElectronicsReplies: 0Last Post: 28-11-2010, 01:20 PM -
Wiring Help
By Toddy in forum Motor Drivers & ControllersReplies: 8Last Post: 23-11-2010, 01:48 PM
