Thread: Outer cut cutting too deep
03-04-2018 #1
Pleas could you help.
I have just finished a build to my own design, or at least I drew my own plans but followed a tried and tested design.
Anyway less of that, here's my problem, whenever I do a clearance or levelling pass when it does the final pass around the outside it cuts about .2mm lower than the rest of the level, it does this regardless of whether the toolpath is offset or raster.
I am using Vectric Aspire to generate the toolpaths and Mach 3 to control the cnc through a TB6560 controller.
One other thing I am having to work that machine in inches because regardless of what I do I can not get it to work in millimetres.
If I save the same toolpaths in metric and run them on my little chinese 6040 then they work perfectly.
Anybody got any idea's that may help me.
04-04-2018 #2
Zip and attach a sample of code where the part has both the Inch/mm issue and the depth issue.
Inch/mm is most likely you PP not setting units. G20/G21You think that's too expensive? You're not a Model Engineer are you? :D
4.3 mm holes, 20 mm deep
By Chaz in forum Metalwork DiscussionReplies: 26Last Post: 08-08-2017, 10:46 PM -
just how deep does a water trough need to be?
By nobby in forum Plasma Table MachinesReplies: 1Last Post: 09-07-2017, 04:27 PM -
Speeds and feeds deep drilling
By Razorab in forum Sieg Milling MachinesReplies: 13Last Post: 10-02-2013, 09:00 PM -
How deep can i cut MDF?
By MrWiz73 in forum Machine DiscussionReplies: 6Last Post: 24-08-2011, 10:38 PM
