27-01-2018 #5
I was thinking these
https://www.ebay.co.uk/itm/15mm-line...cAAOSwNWxaJP-~
I could butt 2 together to get lengths I desire so £240 would support 2 3m lengths.
The choices so far
1. 2* 2525 ballscrew 2.7m with decent quality BK/BF fittings ~£1000
2. 2* 3232 2.5m with fittings ~£1500
3. 2* 2010 with fittings 2.7m length fully supported with the clone rail and 2 carriages per ballnut leaving me 4 spare carriages in total, I could then use 6 carriages to support the Z axis which has the same rail on it given me 50% more strength without affecting travel. ~£600
I would think the 2 biggest factors in critical speed are how straight is the ballscrew and how good are the bearings in the BK/BF fittings, I might even play with type C mounting method but I believe this needs super precision although doubling your criticial speeds.
Resolution is not so relevant as I'll use servos, not sure how powerful but was told 400w should be ok I think £2k will buy the servos and the mesa controller so I can use linuxcnc.
I really want to direct drive with oldham coupling but it can be belt driven I suppose, the most important things are large travel, good accuracy and good speed.Last edited by Desertboy; 27-01-2018 at 10:14 AM.
WANTED: Supported rail - a couple of lengths of any size for an experiment!
By GND in forum Items WantedReplies: 0Last Post: 29-11-2016, 02:16 PM -
NEW MEMBER: Hi,Friend,I'm a B2C seller from China for ballscrew,linear guide,linear shaft etc.
By yvesleeok in forum New Member IntroductionsReplies: 11Last Post: 10-08-2013, 11:15 AM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
Linear rail and ballscrew dimensioning for R/C router
By CarlNicholasCarlsson in forum Linear & Rotary MotionReplies: 0Last Post: 24-03-2013, 06:52 PM -
Using SBR12 as ballscrew end support
By Lovre in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 13-12-2012, 08:52 PM
