Thread: Drill/Mill Spindle brake (RF30)
Finished! New belt arrived today - no more buzzing noise.
Changing the front belt I can get speeds from 175 to 1860 in four over lapping ranges.
Pulley Vmin - Vmax
1 == 548 - 1860
2 === 393 - 1409
3 ==== 290 - 977
4 ===== 175 - 633
19-09-2009 #2
So basically if you only ran 1 and 4 you would have the whole range ?
What about doing just a two speed pulley using a 6 rib Poly vee belt drive and that way you could get the smaller pulley on the intermediate shaft a tad smaller without loosing wrap round as Poly vees' don't suffer from this like V belts and you could probably get to less than 100 rpm.
Mind you if you are on CNC then it's a different ball game to the manual owner who needs low revs for large cutters and boring.John S -
19-09-2009 #3
Yes, that would do it. The front pulley on these machines fits on a large taper so I'd have to make the poly V pulley...
I started thinking seriously about this conversion after I discovered that the original motor step-pulley was the wrong type ('A' section not 'B') I wanted to replace the belts with Fenner's (since they're supposed to be better) and did not want to run them on the wrong pulley. 'B' section step pulley aren't available of the shelf, so I was facing either making one or trying this; I'm glad I chose the later 'cos this works nicely :)
02-11-2009 #4
Just thought I'd share this with you...
My nephew Lee has a bad habit of asking me to make him things out of stupid sized bits of metal; a couple of weeks ago he asked me to make him a 35mm diameter steel sleeve with a 25mm bore and then supplied a length of 50mm bar - I couldn't find any 40mm bar locally, so had to spend hours turning the bloody thing down.
Saturday, he dropped off a 'technical' drawing - anyone who has seen the The film "The Hudsucker Proxy" would have recognised the drawing straight away i.e. two roughly concentric circles with 120 written in the middle and 12 by the edge with a side note saying 100mm long.
With it came a 4" long by 6" diameter block of steel - I'm suppose to make it into a tubeLast edited by BillTodd; 04-11-2009 at 12:14 AM.
04-11-2009 #5
I wasn't happy about mounting the rough outside of the block in the lathe, so I finished the bore on the RF30 drill/mill
After a very noisy interrupted cut, the boring job when quite smoothly.
Last act was to turn the outside to size on the latheLast edited by BillTodd; 04-11-2009 at 12:14 AM.
FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
By komatias in forum Items For SaleReplies: 0Last Post: 04-08-2013, 10:30 PM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
WANTED: Small CNC Drill/Mill
By Mad Professor in forum Items WantedReplies: 0Last Post: 03-09-2010, 01:28 PM -
Is it possible to modify a drill to be an end mill?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 4Last Post: 29-04-2010, 02:51 PM -
Help with drill-Mill conversion
By Ross77 in forum Milling Machines, Builds & ConversionsReplies: 134Last Post: 02-04-2010, 10:25 AM
