Thread: Haimer 3d taster 20mm shank
Haimer 3D Taster with 20mm shank. can probe in all XYZ axis.
Exact positioning of the spindle axis on the edges of the workpiece
Smallest unit of measure of 0.0004"
Replaceable probes for maximum flexibility IP 67 waterproof
Box Opened but has not been used
Great alternative to an expensive Renishaw probe
Allows quick datum setting of workpieces.
https://www.ebay.co.uk/itm/302612028...84.m1555.l2649
28-01-2018 #2
Simply search "Haimer 3D Taster issues"
Great while they work, useless once they fail, even the company that makes them cannot reliably repair them!
I wouldn't touch one with yours! ;-)You think that's too expensive? You're not a Model Engineer are you? :D
05-02-2018 #3
05-02-2018 #4
It depends how you work, I have a 10mm shank edge finder as my primary reference tool in the tool table, but I also have a modified electronic LED edge finder with a sprung ball tip which is nice.
Copier paper is reliably 0.1mm thick for edge and surface finding with actual tooling, if you want to use a small hole as a reference get a pointed centre finder, lower it into the hole until the taper section encounters friction then feel the shaft (f'nar, f'nar) for the step and jog to position, like the Mk1 Eyeball the Mk1 Finger is a much underestimated tool.You think that's too expensive? You're not a Model Engineer are you? :D
05-02-2018 #5
I obviously had the same thought you did
I had an idea about those LED things, twigging on to the circuit with the LED and wiring it in to the control as an N/O probe. Don't know if possible, or worthwhile.
Reckon I'll still go with the Haimer, if it lasts a few years its money well spent IMO.
Haimer 3D - Calibration Problems
By matt-b2 in forum Tool & Tooling TechnologyReplies: 16Last Post: 16-08-2017, 07:55 PM -
Haimer 3d taster probe unboxing video
By Dangle_kt in forum Workshop & EquipmentReplies: 0Last Post: 13-03-2017, 06:46 PM -
WANTED: ER20/25 straight shank collet chucks
By m_c in forum Items WantedReplies: 4Last Post: 24-10-2011, 12:19 PM -
Leitz Router Bit, Odd Shank Size?
By gazza in forum Tool & Tooling TechnologyReplies: 4Last Post: 27-02-2011, 03:26 PM -
What size (3mm shank) ball endmill should buy?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 16Last Post: 28-07-2009, 12:07 AM
