Thread: Haimer 3d taster 20mm shank
	05-02-2018 #4
It depends how you work, I have a 10mm shank edge finder as my primary reference tool in the tool table, but I also have a modified electronic LED edge finder with a sprung ball tip which is nice.
Copier paper is reliably 0.1mm thick for edge and surface finding with actual tooling, if you want to use a small hole as a reference get a pointed centre finder, lower it into the hole until the taper section encounters friction then feel the shaft (f'nar, f'nar) for the step and jog to position, like the Mk1 Eyeball the Mk1 Finger is a much underestimated tool.You think that's too expensive? You're not a Model Engineer are you? :D
Haimer 3D - Calibration Problems
By matt-b2 in forum Tool & Tooling TechnologyReplies: 16Last Post: 16-08-2017, 07:55 PM -
Haimer 3d taster probe unboxing video
By Dangle_kt in forum Workshop & EquipmentReplies: 0Last Post: 13-03-2017, 06:46 PM -
WANTED: ER20/25 straight shank collet chucks
By m_c in forum Items WantedReplies: 4Last Post: 24-10-2011, 12:19 PM -
Leitz Router Bit, Odd Shank Size?
By gazza in forum Tool & Tooling TechnologyReplies: 4Last Post: 27-02-2011, 03:26 PM -
What size (3mm shank) ball endmill should buy?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 16Last Post: 28-07-2009, 12:07 AM
