    I'm guessing that it isn't done because it involves increased complexity and cost but if the table and gantry screws were driven by one drive system linked with toothed belts and pulleys of the appropriate ratios and directions then it could be done without any software integration of the two movements in the same axis.
    Interesting thought!
    This has been done before with Mach3. It's not massively complex but does require some special coding or formula's to be created I think.
    I'll see if I can find a link to a thread of someone who's done it.
    This is one way but I've seen better way using formulas in mach3 just cannot find it yet, but I will.
    http://www.cnczone.com/forums/cnc-wo...ml#post1217301
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    If you design both drive systems to use a similar number of steps for full travel, just slave them, and adjust the steps per mm/inch to suit.
    Great - it's not a crazy idea!
    I need to research whether gearing, formulas or 'slaving' is the way to go as well as how much cost/complexity it will add. As if learning the basics wasn't mind-boggling enough...
    Thanks all.
  1. BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
    By GeorgeW21 in forum DIY Router Build Logs
    Last Post: 20-01-2019, 09:33 AM
  2. Help Please for Moving Gantry
    By endlasuresh in forum Gantry/Router Machines & Building
    Last Post: 08-11-2017, 12:15 PM
  3. Now That's a Serious 4-Axis Moving Gantry Machine!
    By magicniner in forum Machine Discussion
    Last Post: 31-03-2017, 07:43 PM
  4. BUILD LOG: "Henge", 3 Axis Cnc, Fixed Gantry, Moving Table
    Last Post: 20-03-2017, 08:43 PM
  5. Vertical moving gantry????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 03-06-2009, 08:34 PM
