    This has been done before with Mach3. It's not massively complex but does require some special coding or formula's to be created I think.
    I'll see if I can find a link to a thread of someone who's done it.
    This is one way but I've seen better way using formulas in mach3 just cannot find it yet, but I will.
    http://www.cnczone.com/forums/cnc-wo...ml#post1217301
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    If you design both drive systems to use a similar number of steps for full travel, just slave them, and adjust the steps per mm/inch to suit.
    Great - it's not a crazy idea!
    I need to research whether gearing, formulas or 'slaving' is the way to go as well as how much cost/complexity it will add. As if learning the basics wasn't mind-boggling enough...
    Thanks all.
  1. BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
    By GeorgeW21 in forum DIY Router Build Logs
    Last Post: 20-01-2019, 09:33 AM
  2. Help Please for Moving Gantry
    By endlasuresh in forum Gantry/Router Machines & Building
    Last Post: 08-11-2017, 12:15 PM
  3. Now That's a Serious 4-Axis Moving Gantry Machine!
    By magicniner in forum Machine Discussion
    Last Post: 31-03-2017, 07:43 PM
  4. BUILD LOG: "Henge", 3 Axis Cnc, Fixed Gantry, Moving Table
    Last Post: 20-03-2017, 08:43 PM
  5. Vertical moving gantry????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 03-06-2009, 08:34 PM
