    Chaz's Avatar
    Anyone running SimCNC? Just tried it, spent ages on it. Axis were drifting on their own, solved that with Zero offset. But I cannot PID tune and all I get are motors that shake and PID error.
    Thoughts?
    Chaz's Avatar
    Ok, got it to work.
    The PID values in Mach 3 are not nearly transferable, wiped them to zero, enabled the drive, disabled commands to it, ran auto tune for all 3 axis.
    What's strange at the moment is the fact that I cant run a programme whilst the MPG is enabled.
    Chaz's Avatar
    Turns out that the MPG should not have its enable signal hardware but should be switched. Odd setup I think.
    I cant find any info on how / where to do any backlash settings.
    Nice looking software, seems decent but feels somewhat unfinished.
    A pity. I can see me moving this machine to Centroid Acorn at some point.
    Chaz have you used simcnc any more since your last post here? I've got a mill which came with an unfinished csmio-ip/a retrofit, I'm wondering whether to keep it or swap it out, you're the only person here who seems to have tried sim... any further thoughts?
    Chaz's Avatar
    Quote Originally Posted by Steve_p View Post
    Hi. I used it a bit. If I owned a license, I reckon I would have stayed using it. It feels more stable / accomplished than Mach 3. Currently using Mach 4 as there was no cost to me for it. Just rewiring my machine at the moment in preparation for a potential house move, so will start to use the machine more once that is done.
    It seems like a decent bit of software. My biggest concern (ignoring the additional cost) is lack of support / few people use it. So if you want to solve an issue or get a macro sorted, you might struggle. CS Labs themselves will respond but I find it takes long and then they often only answer some or a few questions and ignore the rest.
    They have some basic macro guides - think based on Python, need to check, but not a lot more.
    Whereas if you look at Centroid, you will see an excess of documentation and active users helping each other - I dont see this in the CS Labs ecosystem.
    Hi all.
    I have been trying to find information about the CSlabs software and found this thread and thought I would revive it to see if anything else has happened in the last 9 months.
    Sorry to bring an old thread back from the dead. But, I was wondering if anyone had started to use this software as I am thinking about jumping from Mach3 to sim cnc. I was looking at upgrading to Mach 4 but I have not heard great things about it and that CSL were not fixing bugs as quickly as they once did.
  1. looking for a pendant to work with Cslabs ip-m mach 3
    By charlieuk in forum CS-Lab (CSMIO)
    Last Post: 22-09-2017, 03:56 PM
  2. Replies: 15
    Last Post: 05-01-2016, 08:52 AM
  3. Spindle on/off under CNC software control - safety worries!
    By HankMcSpank in forum Machine Control Software
    Last Post: 12-02-2013, 03:47 AM
  4. Replies: 2
  5. servo control vs stepper control
    By Peter. in forum Motor Drivers & Controllers
    Last Post: 17-09-2012, 08:36 AM
