    -(feedrates in mm)-
    I'm playing with cutting aluminium.
    I used Artcam 2018 to make a simple 20mm Circle ,5mm deep for offset clearance, starting in the middle.
    6mm carbide end mill, set to 10,000 RPM and a Feedrate of 300. I generate and export TAP file.
    In my TAP file, feed is set to F360 (not 300) until it plunged and does the first 'inner' pass. Then feedrate jumps to F18,000 for outer part of circle!!
    I edited TAP file to make all feedrates F360 and it ran perfectly.
    My question is, why F360 instead of 300 and where the hell did artcam dig up F18,000 from?
    Thanks.
    Here is the tap file.
    20mm hole -TAP.txt
    Okay- after spending the day on google, I've found the problem.
    My tool database is in mm per second and toolpath uses mm per minute. My feedrates are being multiplied x60!
    Anyone know how to sort this?
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    Change your database, or change your post processor.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. SOS Artcam
    By luke11cnc in forum General Discussion
    Last Post: 21-03-2017, 12:08 PM
  2. Today only ArtCAM Special
    By Ger21 in forum Artcam
    Last Post: 31-01-2017, 04:58 PM
  3. Replies: 49
    Last Post: 20-10-2013, 04:15 PM
  4. Countersink Cutter Feed & Speeds
    By Mad Professor in forum Tool & Tooling Technology
    Last Post: 01-02-2013, 09:34 PM
  5. Artcam
    By luke11cnc in forum Artcam
    Last Post: 07-05-2012, 11:28 AM
