01-02-2018 #1
-(feedrates in mm)-
I'm playing with cutting aluminium.
I used Artcam 2018 to make a simple 20mm Circle ,5mm deep for offset clearance, starting in the middle.
6mm carbide end mill, set to 10,000 RPM and a Feedrate of 300. I generate and export TAP file.
In my TAP file, feed is set to F360 (not 300) until it plunged and does the first 'inner' pass. Then feedrate jumps to F18,000 for outer part of circle!!
I edited TAP file to make all feedrates F360 and it ran perfectly.
My question is, why F360 instead of 300 and where the hell did artcam dig up F18,000 from?
Thanks.
01-02-2018 #2
Here is the tap file.
20mm hole -TAP.txt
02-02-2018 #3
Okay- after spending the day on google, I've found the problem.
My tool database is in mm per second and toolpath uses mm per minute. My feedrates are being multiplied x60!
Anyone know how to sort this?
02-02-2018 #4
Change your database, or change your post processor.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
SOS Artcam
By luke11cnc in forum General DiscussionReplies: 0Last Post: 21-03-2017, 12:08 PM -
Today only ArtCAM Special
By Ger21 in forum ArtcamReplies: 3Last Post: 31-01-2017, 04:58 PM -
Is Somebody messing with Forum layout? . . Lost Latest post's.!!!
By JAZZCNC in forum General DiscussionReplies: 49Last Post: 20-10-2013, 04:15 PM -
Countersink Cutter Feed & Speeds
By Mad Professor in forum Tool & Tooling TechnologyReplies: 0Last Post: 01-02-2013, 09:34 PM -
Artcam
By luke11cnc in forum ArtcamReplies: 5Last Post: 07-05-2012, 11:28 AM
