    The mesa stuff is known to drive motors/servos well.
    Granite D. is actually cheap ..
    Getting any of the commercial/fanuc servos running well has been an adventure, in general, for others.
    It will be very cheap to try with a granite d. system, vs anything else ..
    and about 3x easier, imho.
    There are endless caveats, most are unlikely.
    So it might be it wont work .. but this is 5-10% probability.
    Using the granite d. stuff makes you 10x more likely to succeed - imho.
    Ross here is the link to the drives https://granitedevices.com/products/
    and a page that might be able to walk you through http://www.wiki.eusurplus.com/index.php?title=Main_Page
    as you know I am following this
    So a big plus for Granite devices then
    Not sure I class £420 a drive as cheap though, Would the IONI series be powerfully enough? Modular so I could build up the system as I need it.
    Thanks Clive, hadnt found that wiki but looks promising, I could even use my current mesa cards as the GD's accept step direction signals as well as 0-10v
    Had a look today and the motors are Type 3-OS, A06B 0533-B001#7000 and dated 90 04 so guesing April 1990
    6 pole, 112v, 0.5Nm and 1 amp, google seems to indicate a 2000ppr incremental encoder.
    Are they worth saving or just replace with a all new drives.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I'd price the different options up.
    How much are a pair of drives suitable for those motors?
    How much would it cost if one of those motors died (the actual motor is unlikely, but the encoder might)?
    How much is a set of new servos/drives?
    How much would ou get selling the Fanuc system/motors?
    Personally I'd replace with new, so I've got a known quantity, and know where to get spares, but then I'm looking at things from a commercial point, where if something breaks, I want to know what's needed and where to get it, to fix it ASAP.
  6. The Following User Says Thank You to m_c For This Useful Post:
  7. #6
    My main aim is to keep the accuracy of the machine. I keep seeing posts that say the Fanuc set up is the best and its mad to replace with steppers.
    I was also trying to keep the work load down and get it running Asap by just a rewire and not have to mess with pullies and belts.
    Any idea on the value of a Fanuc OT system?
    I know how much the Granite drives units are to run the Fanuc motors but there is such a variety of replacement servos and drives I have no idea what is the best option.
    What nema 34 servo motors and drives would you recomend?
  8. #7
    I can understand keeping things simple.
    I have no idea about Fanuc values, but I know there are people who buy machines just to get the control, then scrap the machine.
    Nema34 is 69.58 square distance between mounting holes, and 86 overall square.
    Those servos are not actually that powerful. 112V and 1A puts them at 120W continuous (there will likely be an instantaneous rating 2-3x this).
    Kinco from Zapp, you could go for SMH60 400W servos which are £264 along with a CD422 drive at £240 makes it £504 per axis (those prices are including VAT).
    If you go for a Chinese option, 200W servo and drive combos can be had $264 per set (https://www.aliexpress.com/item/New-...760383887.html) or 400W for a similar price (https://www.aliexpress.com/store/pro...760376015.html with an 80 frame motor, or https://www.aliexpress.com/store/pro...760394727.html with 60 frame motor)
    Or I've just remembered CNCdrive do servos and drives. They do AC servos in 156 and 400W versions at €156 and €198 respectively, although I can't find their corresponding drive in their web shop. They also do DC brushed servos, but I'd personally pay the extra for AC servos.
  1. Fanuc OT - Fuses blowing
    By Cube3 in forum Machine Control Software
    Last Post: 19-07-2017, 08:03 PM
  2. Fanuc w3 paramaters
    By Ismirko in forum Machine Discussion
    Last Post: 03-02-2015, 08:29 PM
  3. NEW MEMBER: Fanuc Macro programming
    By curly3456 in forum New Member Introductions
    Last Post: 02-02-2012, 10:20 PM
  4. Fanuc, any one know this well, need pointers/help
    By fastcarl in forum Machine Control Software
    Last Post: 26-08-2011, 07:46 AM
  5. Leadwell/ Fanuc Om control manual
    By fastcarl in forum Machine Discussion
    Last Post: 26-06-2011, 11:09 AM
