Thread: Sieg C3 backlash problem
Idly searching for info on the C3 DRO (to get ideas for my own) I cam across the arceurotrade site where, against the C3 DRO info it states:
Note:
Depending on the actual lathe, you may experience some mechanical backlash. This can be removed by adjusting (machining or shimming) the collar under the handle.
If you find the instructions in the manual are limited, you may wish to refer to the following web link for more comprehensive details: http://www.mini-lathe.com/Minilathe/Reviews/SiegDRO/dro2.htm
Is this an example of what backlash can do?
By Minnican in forum Machine DiscussionReplies: 19Last Post: 06-03-2011, 08:59 PM -
backlash mack3
By h4ppy-chris in forum General DiscussionReplies: 9Last Post: 29-01-2011, 01:11 PM -
Sieg X3 backlash...
By Vikash in forum General DiscussionReplies: 0Last Post: 20-10-2010, 02:51 PM -
Positive backlash???
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 18-08-2010, 05:04 PM -
Commercial Sieg X1 anti backlash nuts ?
By cweeks in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 28-05-2009, 06:41 PM
