    Has anyone used the Granite Devices Ioni system? is it easy to use?
    Looks quite compact and can run most motor types. the only issue I can see is max motor voltage of 55V.
    Chaz's Avatar
    I had a Granite Device system but it needed a lot of DIY to get it going. I ended up sending it back and going through a Paypal dispute (which went in my favour) to get my money back.
    What exactly ware you trying to do?
    Not good then! was that the Ioni?
    Initially I was looking to use it to retrofit my lathe but I have a few other projects that need a mix of drives so the multi-functional output seemed appealing for neatness and quick changes.
    Chaz's Avatar
    Sorry for the slow response, no, it was this.
    https://granitedevices.com/store/arg...rvo-drive.html
  1. How flat is a granite worktop?
    Last Post: 02-06-2021, 03:42 PM
  2. Granite Surface Plate - Cracked?
    By camhguh in forum Workshop & Equipment
    Last Post: 27-11-2016, 02:57 PM
  3. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 06:21 PM
  4. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 07:28 PM
  5. How to make Clamping Devices
    By Lee Roberts in forum Machine Discussion
    Last Post: 16-11-2009, 05:40 PM
