    Thanks again JAZZ, that went slightly beyond the question asked! I do have one final question before I attempt a rough plan and start a build thread please, should be an easy one.
    A 400x400 cutting area will take up nearly double the space compared to my planned 400x200 which is already bigger than I can think of a use for - why do you recommend this size? I'll need a bigger table!
    Quote Originally Posted by suicidal_orange View Post
    Well suppose yes but same time no not really because only gave you the basic run down and you'll need to know this info to come up with good design/machine which suits your needs.
    Well, really it was just to give an idea of a small machine with a reasonable cutting area that gave little room to expand from what you think you need.!!
    Like I said size is relevant to the user or purpose. However, I can tell you as will others with 99.9% certainty that when getting into CNC you'll want to tackle larger jobs and soon even 400x400 won't be enough.!
    Don't forget you will need hold down clamps on the table as well.
    This is why half of me still thinks I should buy a near useless <£150 Chinese 1610 or similar - I can't forget about clamps as I'd never thought of them! Just had a look and seems you're supposed to make them out of wood so can't really see how much bed I'll lose. Very random...
    Thanks for pointing out what should have been obvious!
    I've just measured and I have 405x910mm of table so 400x400 travel isn't going to fit. That leaves me with two options: 400mm (or bigger? Don't think there's any point...) fixed gantry with 200mm travel bed using a rack and pinion (no room for a motor on the already small 200mm axis or a 300/350mm fixed gantry (depending how thick the sides are) with 450mm travel bed, which could use ballscrews.
    Apart from the drive everything will be the same apart from lengths so I can plan most of it and decide on the size later (you and everything I've read say you always want bigger so if budget allows why not)
    I'm now wondering how much weight the table can take though, and whether it needs to be level and/or flat. I was thinking 4 feet in the corners would be sufficient as the frame will be rigid by design but hadn't considered weight at all. Any suggestions for testing a table without destroying it?!
    I still have plenty of reading to do - thanks again for the solid intro.
  5. Homemade wooden countertops with a 200mm moving gantry or a 400mm fixed gantry with a moving bed. It is a choice I have seen. If you make it yourself, the price will be better controlled. Even the size can be measured on the spot according to the size of the garage. Or use the metal countertops of the factory directly, which is also a good choice.
  1. Design of small router (700x900) for aluminium
    By Edward in forum Gantry/Router Machines & Building
    Last Post: 16-12-2017, 07:34 PM
  2. RFQ: Small run of parts in aluminium
    By CHudson in forum Projects, Jobs & Requests
    Last Post: 06-10-2017, 04:12 PM
  3. BUILD LOG: Small workshop CNC router, steel base, planning on ATC
    By spresv in forum DIY Router Build Logs
    Last Post: 07-02-2017, 04:28 PM
  4. Small desktop mill/router for cutting <=6mm aluminium
    By matt-b2 in forum Marketplace Discussion
    Last Post: 08-12-2013, 01:04 AM
  5. BUILD LOG: Planning and build of my "8020" aluminium CNC Router
    By monza in forum DIY Router Build Logs
    Last Post: 06-02-2010, 11:55 PM
