09-02-2018 #5
Thanks JAZZ
As I said I'm planning to a spec greater than I need and will not buy anything until the plan is complete, cost is the second consideration (if the plan to do what I want is too expensive it just won't happen)
It's hard to come up with a design when everything I read seems to talk in 'small' and 'large' machines with no indication what this means - if it said a rail less than 300mm is small, more than 600mm is large that would be meaningful, the words alone are not...
My main planned use is 60% keyboard cases which are basically hollowed out blocks of around 290x110x30mm - proper aluminium milling. The Z axis is big to allow for drilling holes in the back and so I can add a 4th axis at a later date.
Would be good to know what of the above leads you to suggest fixed or moving gantry please, I want to learn.
Design of small router (700x900) for aluminium
By Edward in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 16-12-2017, 07:34 PM -
RFQ: Small run of parts in aluminium
By CHudson in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-10-2017, 04:12 PM -
BUILD LOG: Small workshop CNC router, steel base, planning on ATC
By spresv in forum DIY Router Build LogsReplies: 24Last Post: 07-02-2017, 04:28 PM -
Small desktop mill/router for cutting <=6mm aluminium
By matt-b2 in forum Marketplace DiscussionReplies: 2Last Post: 08-12-2013, 01:04 AM -
BUILD LOG: Planning and build of my "8020" aluminium CNC Router
By monza in forum DIY Router Build LogsReplies: 14Last Post: 06-02-2010, 11:55 PM
