Yeah I had to check my phones pics and 29/06/16
Never planed on cutting alloy just the odd part but done more than a few now, may need an upgrade
or modification.
That's the second tower I machined and I had a 15psi regulator and an iffy mist system, both not reliable.
Now I've got a new reg 30 psi and mist system that actually works
Yes I have spiral but only used to interpolate holes, never used on profiles so maybe try that instead
But I don't plunge anyway I used ramp
Tbh Dean it's the only time I used HSS was been a tight ass and if it broke or a massive fail it was only £24 gone, but worked well so stuck with it and it's a ripper in the vid leaving .25 for a finish pass with a 4mm carbide 3 flute.
If I tap carbide in my app is calls for almost 24k but 7000 mm/min
Running carbon parts and plastic parts I'm at 24k all the time.
But I'm pretty new to cutting alloy done the odd part here and there but not really enough to gain any real learning from it.Last edited by Dean jeffery; 14-02-2018 at 02:56 PM.
14-02-2018 #2
Don't mean spiral tool entry into the material, suppose could be called ramped profile.?. The toolpath I'm talking about will ramp/spiral down the whole way around the profile to the depth you set.
Ie set 3mm doc and it starts at Z0 and does one lap until reaches until reaches 3mm then does another until reaches 6mm etc. It never lifts or retracts tool until at the finished depth.
It's much faster and less stressful on tooling.Last edited by JAZZCNC; 14-02-2018 at 09:46 AM.
Help with speeds/feeds please?
By examorph in forum Tool & Tooling TechnologyReplies: 5Last Post: 29-01-2017, 01:54 PM -
Speeds and feeds
By eurikain in forum Workshop & EquipmentReplies: 3Last Post: 26-03-2016, 06:00 PM -
Feeds and speeds software
By suesi34e in forum Swarf & Chip ManagementReplies: 4Last Post: 22-03-2016, 10:30 PM -
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM
