Yeah it's been a great machine around 19 months old now.
F360 and the likes is a bit to much of a learning curve, I don't have the time to learn it work loads increasing and limiting even custom work.
But adaptive would band those alloy parts out way quicker, still only takes 28mins minus cutter changers.
See the vid just starts to change tone last pass.
https://youtu.be/PYtKZlAzJA8
13-02-2018 #2
Bloody hell Dean can't believe been 19mths.!!.... Seems like 6mths. The machine does well to say was never really designed to cut aluminum.!
Listening to that video you need much more air you can hear it re-cutting chips this will cause extra heat with high potential to weld chips to tool also give a poorer finish.
Does your cam software have a function to use spiral tool path? This helps keep constant tool engagement and also quicker and easier on tools because not retracting and plunging at end of each pass.
Also because of high spindle speed/low torque you really need carbide tooling. HSS requires much lower RPM and these spindles don't have enough torque at low speeds. These spindles provide most torque at full RPM so the higher you can run the RPM the better and with HSS tools your always going to struggle.
Carbide lasts much longer and can be pushed much harder. Often people don't push them hard enough so when the get chatter etc they back off when often all they need to do is increase feed rates which changes the tool pressure. Obviously there's limit and machine strength does then start coming into play.Last edited by JAZZCNC; 13-02-2018 at 08:37 PM.
13-02-2018 #3
Yeah I had to check my phones pics and 29/06/16
Never planed on cutting alloy just the odd part but done more than a few now, may need an upgradeor modification.
That's the second tower I machined and I had a 15psi regulator and an iffy mist system, both not reliable.
Now I've got a new reg 30 psi and mist system that actually works
Yes I have spiral but only used to interpolate holes, never used on profiles so maybe try that instead
But I don't plunge anyway I used ramp
Tbh Dean it's the only time I used HSS was been a tight ass and if it broke or a massive fail it was only £24 gone, but worked well so stuck with it and it's a ripper in the vid leaving .25 for a finish pass with a 4mm carbide 3 flute.
If I tap carbide in my app is calls for almost 24k but 7000 mm/min
Running carbon parts and plastic parts I'm at 24k all the time.
But I'm pretty new to cutting alloy done the odd part here and there but not really enough to gain any real learning from it.Last edited by Dean jeffery; 14-02-2018 at 02:56 PM.
14-02-2018 #4
Don't mean spiral tool entry into the material, suppose could be called ramped profile.?. The toolpath I'm talking about will ramp/spiral down the whole way around the profile to the depth you set.
Ie set 3mm doc and it starts at Z0 and does one lap until reaches until reaches 3mm then does another until reaches 6mm etc. It never lifts or retracts tool until at the finished depth.
It's much faster and less stressful on tooling.Last edited by JAZZCNC; 14-02-2018 at 09:46 AM.
Help with speeds/feeds please?
By examorph in forum Tool & Tooling TechnologyReplies: 5Last Post: 29-01-2017, 01:54 PM -
Speeds and feeds
By eurikain in forum Workshop & EquipmentReplies: 3Last Post: 26-03-2016, 06:00 PM -
Feeds and speeds software
By suesi34e in forum Swarf & Chip ManagementReplies: 4Last Post: 22-03-2016, 10:30 PM -
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM
