    hi
    Could anyone assist me in adding these cheap engraving bits into the tool library on fusion 360?
    http://www.ebay.co.uk/itm/New-10pcs-...EAAOSwPcVVwaOH
    1. The cost of them has no bearing on it.
    2. The tool library of what ?
    Fusion 360 obviously. look at the category op posted in
    Have you tried Google? There's a whole bunch of stuff if you look for something like "Fusion 360 add tool to library". The Youtube videos by NYC CNC are well-regarded and he has one, I see. It's a pretty straightforward thing to do, once you have found out what the important parameters are as opposed to the ones you can ignore (bit like much of F360, in fact). Ignore things like "toolholder", for example. It's important for some things, but safe to ignore when you're getting started.
    Correct the cost is irrelevant but the diameter information on the link probably is.
    I put this post in the Fusion 360 section so assumed people would know its for doing this on fusion 360.
    Yeah ive had a look but i was surprised to see you cant add them in as a actual v bit. Ill have to add them as chamfer or somehting similiar.
    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,984. Received thanks 369 times, giving thanks to others 9 times.
    Quote Originally Posted by dfox1787 View Post
    A V bit is just a type of chamfer cutter...
    ...and F360 appears to allow you to enter a 0mm tip diameter to make it a V-cutter.
    I did wonder about the question as the "tool entry" mechanism is pretty straightforward. All is now clear!
    this best i could do with this tool
    https://www.ebay.co.uk/itm/60-Degree...4AAOSw44BYKvQk
    If you want amore accurate representation, use a Tapered Mill, and set the tip diameter to 0.0000001.
  1. adding high speed spindle
    By jerome in forum Milling Machines, Builds & Conversions
    Last Post: 21-12-2017, 08:19 PM
  2. adding engraving plug in
    By kell in forum Artsoft Mach (3 & 4)
    Last Post: 18-03-2016, 10:14 AM
  3. Adding 3D printer ability to my CNC / advice needed please
    By dudz in forum 3D Printing Machines
    Last Post: 16-02-2015, 08:35 PM
  4. Replies: 4
    Last Post: 02-04-2012, 03:40 PM
  5. Adding a 'Park Mode' to a cnc router?
    By routercnc in forum Computer Software
    Last Post: 18-06-2010, 06:10 PM
