    A V bit is just a type of chamfer cutter...
    ...and F360 appears to allow you to enter a 0mm tip diameter to make it a V-cutter.
    I did wonder about the question as the "tool entry" mechanism is pretty straightforward. All is now clear!
    this best i could do with this tool
    https://www.ebay.co.uk/itm/60-Degree...4AAOSw44BYKvQk
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    If you want amore accurate representation, use a Tapered Mill, and set the tip diameter to 0.0000001.
    thank you that does look more like it.
    I think they should just add the v bit option to the tool selection.
    Would the tapered angle be 30 degrees for a 60 degree bit?
  1. adding high speed spindle
    By jerome in forum Milling Machines, Builds & Conversions
    Last Post: 21-12-2017, 08:19 PM
  2. adding engraving plug in
    By kell in forum Artsoft Mach (3 & 4)
    Last Post: 18-03-2016, 10:14 AM
  3. Adding 3D printer ability to my CNC / advice needed please
    By dudz in forum 3D Printing Machines
    Last Post: 16-02-2015, 08:35 PM
  4. Replies: 4
    Last Post: 02-04-2012, 03:40 PM
  5. Adding a 'Park Mode' to a cnc router?
    By routercnc in forum Computer Software
    Last Post: 18-06-2010, 06:10 PM
