    Dave,
    Looking at the drawing of the j head i would find someone who repairs these spindles for advice. You need the full bearing number for the angular contact matched pair. If you get the number they will be much cheaper from one of the bearing suppliers. Also what grease is required and what preload?
    Trouble with rebuilders is that they quote the really expensive item as their reputation is on the line.
    In the end i cleaned and refitted the original bearings, they were genuine and marked with custom grind codes for the pre-load as well as alignment marks. Pre-load is set in the bearings as the spacer collars are identical in length, i think if you fit un-ground bearings you need to get the spacers ground for pre-load.
    No grease - this head is oil lubricated, total-loss system.
  1. How to properly run in spindle bearings.
    By driftspin in forum Generic Chinese Spindles
    Last Post: 22-11-2018, 04:11 PM
  2. FOR SALE: rails, screws, bearings and spindle
    By wilfy in forum Items For Sale
    Last Post: 10-04-2013, 01:50 AM
  3. That old chestnut..
    By Ricardoco in forum Gantry/Router Machines & Building
    Last Post: 14-08-2012, 12:16 PM
  4. spindle bearings overheating
    By Andrew Wilding in forum Spindles & Drive Motors
    Last Post: 15-05-2011, 01:21 PM
  5. DIY Spindle - What type of bearings are best suited for a spindle.
    By 8iggles in forum Spindles & Drive Motors
    Last Post: 09-02-2011, 10:15 PM
