Trouble with rebuilders is that they quote the really expensive item as their reputation is on the line.
In the end i cleaned and refitted the original bearings, they were genuine and marked with custom grind codes for the pre-load as well as alignment marks. Pre-load is set in the bearings as the spacer collars are identical in length, i think if you fit un-ground bearings you need to get the spacers ground for pre-load.
No grease - this head is oil lubricated, total-loss system.
How to properly run in spindle bearings.
By driftspin in forum Generic Chinese SpindlesReplies: 8Last Post: 22-11-2018, 04:11 PM -
FOR SALE: rails, screws, bearings and spindle
By wilfy in forum Items For SaleReplies: 16Last Post: 10-04-2013, 01:50 AM -
That old chestnut..
By Ricardoco in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 14-08-2012, 12:16 PM -
spindle bearings overheating
By Andrew Wilding in forum Spindles & Drive MotorsReplies: 9Last Post: 15-05-2011, 01:21 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
