Thread: USB Emulator
Rob,
I can't find any SD cards where transfer to the card is mentioned in the description of functionality, have you found one that does?You think that's too expensive? You're not a Model Engineer are you? :D
21-02-2018 #2
None of the cards mention specifically loading to the card memory with WiFi. These are two I have been looking at https://www.ebay.co.uk/itm/Micro-SDH....c100005.m1851 this is cheaper and to be honest , it is my choice for experimentation. The Toshiba FlashAir ought to have more documentation, but I have yet to find it.
It seems that the FlashAir acts as a Wireless Hotspot, so you have to connect your wifi to it. this puts me off as I already have a WFS210 oscilloscope, which acts on the same principle and it a capricious bugger to connect to my Win7 PC or my Win10 tablet and I have yet to get any success connecting to my Win10 PC.
Cheers,
RobLast edited by cropwell; 21-02-2018 at 12:29 AM.
21-02-2018 #3
You'd think all the 3D printing Gurus would be shouting about wireless SD cards that you can transfer files to, I'd buy one for my printer!
21-02-2018 #4
Looks like with the right version of FlashAir you can, but it's not an intended or supported function :D
https://mattshub.com/2017/04/11/flashair-sd-card/Last edited by magicniner; 21-02-2018 at 10:34 AM.
The Following User Says Thank You to magicniner For This Useful Post:
21-02-2018 #5
21-02-2018 #6
Not sure if the WiFi stick will do the job. It seems more to WiFi whatevers been loaded onto the stick.
Then I had a thought;
All I need is a 4 way 2 pole switch to connect my USB stick to either the PC or the controller!
21-02-2018 #7
Cannabalise 2 USB leads, get a box for the switch and a panel mount USB socket and away you go, just keep lead length to the switch box less than 5 metres for reliability, so you have up to 10 metres of separation and you only have to walk a max of 5 metres to the switch.
21-02-2018 #8
21-02-2018 #9
21-02-2018 #10
There's a good reason why WiFi SD cards (or USB sticks) are generally read only from the wireless connection. If you were to make a change to a file on the SD card via the wireless connection, there is no way of telling the host system it's physically plugged into that the file system has been changed.
So if you try to read a new/changed file, the host system may have cached the old directory structure/file and not be able to see the changes. Or worse, the host computer wants to write some data and overwrites the blocks containing your new file which then corrupts the file system.
File systems that can be modified by two separate clients are quite complicated, and require both clients to know that the file system is volatile (something that SD cards and USB mass storage do not support). So given that 99% of the potential users won't have a clue about how the underlying technology works and simply want something that 'just works' you can see why manufacturers are reluctant to enable this behavior (or won't support it if it is possible), as it would be a nightmare to have to keep explaining it to the non technical users.
From the article about the Toshiba cards, it looks like there is an option on the 3D printer specifically for this. This is likely to make the 3D printer aware that the contents of the card might have changed since it last read something from it. Your controller is unlikely to have this kind of option.
However, if your controller never writes to the USB storage, then you might get away with it if you simply unplug and replug the storage after it's been modified via WiFi.
At this point a clunky switch box sounds even more attractive. ;)Last edited by pinballdave; 21-02-2018 at 11:58 PM.
Which USB parallel port emulator is the best
By bruce_miranda in forum General ElectronicsReplies: 1Last Post: 18-09-2008, 03:38 PM
'Sneaker net indeed, when I started in computing there was only one net everybody used, Annette !
