Thread: USB Emulator
Fortunately the 3D printer only reads files from the root directory of the SD card, so provided that you do not alter the file structure whilst the print is active, I anticipate that there should be no problem. I have yet to receive my Flashair card and reconfigure it to operate in STA mode. This is a side issue from the OP's USB problem and as I am not familiar with the DDSV controller, I have hesitated to offer any solution other than to agree with the OP when he suggested a two way switch. If I had a DDSV, I would probably take on the problem of using a WiFi USB stick, that sort of project intrigues me, but I ain't got one, so I won't. The best guy to give an opinion on the DDSV is probably MadModder.
I suspect that the DDSV will be a simplistic read of the USB when running the Gcode, much the same as the 3D printer, using the stick as a memory extension. The stick would only be read when running a job and I would not think it likely or desirable to mess with the files while chewing metal or wood.
My own CNC machine runs Mach3 from files on my personal cloud and the CNC computer has the Internet gateway disabled, so I have the benefit of LAN access to everything without Microsoft deciding that an update is more important. I apply the principle that, once the job is running, leave the files alone until it finishes.
Having spent 33 years in IT, I am surprised and delighted when something 'just works'.Last edited by cropwell; 22-02-2018 at 01:31 AM.
22-02-2018 #2
My 3D Printer (Marlin based) can and does read from sub-directories.
22-02-2018 #3
02-03-2018 #4
I now have uploaded files to the Flashair card in my 3D printer and just warming up to print. (Actually printing now !)
It was a bit of a struggle, but this is the way I have done it :-
The flashair card was updated to the latest firmware and set to AP mode and the alternative web page according to the instructions in
https://mattshub.com/2017/04/11/flashair-sd-card/. Then I used a WIFI USB dongle to connect to the SSID broadcast by the card, in a computer with a wired connection to my network, so I could access my 3D printing files on a NAS drive.
All a little Heath Robinson, but it works and I don't have to keep farting about swapping the SD card between the computer and the printer.
It should be possible to do the same with a USB connection, just using a SD reader plugged into the USB port.Last edited by cropwell; 02-03-2018 at 06:02 PM.
The Following User Says Thank You to cropwell For This Useful Post:
06-03-2018 #5
Nice one!
Being it's own access point and so not having any internet-facing connectivity seems like common sense rather than Heath Robinson ;-)Last edited by magicniner; 06-03-2018 at 10:50 AM.
08-03-2018 #6
Just as a postscript,(and I know it is not really relevant to this thread) my 3d printer had been playing up on the right extruder. I thought it could be a stepper cable fault, so I replaced the cables to both extruders, which made no difference. On stripping down the hotend, I discovered the thing was choked, so nozzles were put in acetone whilst I waited for the spares I needed to come from Wanhao UK.
Anyway, I got an email acknowledging my order which said they were including a thank-you gift for my past custom.
Todays post brought me the ceramic wraps I needed PLUS an 8GB SanDisk SD card, an all-in-one card reader, a 0.4mm drill, a good quality pair of tweezers and a filament pusher. Did they know it was my birthday last week?
Gobsmacked Rob !Last edited by cropwell; 08-03-2018 at 12:04 AM.
09-03-2018 #7
It's nice to know that a company that isn't open source supports their customers ;-)
Which USB parallel port emulator is the best
By bruce_miranda in forum General ElectronicsReplies: 1Last Post: 18-09-2008, 03:38 PM
